danmcclain2019 wrote:when I put the negative probe in round pin hole 9, and use the positive probe on 5 slot and 6 slot I get 25v on 5 and 6 (on the 9 pin plug)
Burgerman wrote:May be chea[per to just fit a tiny momentary switch elsewhere on the pod. Drill small hole. Small wires and a soldering iron...
https://www.google.com/search?client=fi ... 46fku2bkjM:
danmcclain2019 wrote:Think I really messed up this time, was moving the top piece of the pod and accidently pulled out the ribbon connector for the joystick, bent a few of the pins trying to put it back on...
