gcebiker wrote:Irving wrote:@max71 While I applaud your thinking and determination this isn't something easily done.
But don't let that stop you... maybe you'll be the one to crack it!
Cant be that insurmountable, its a maths / parabolic problem. Instead of the chair driving to the gap directly, drive to it so that it is going through square...or square ish.
Irving wrote:@max71 While I applaud your thinking and determination this isn't something easily done. A colleague of mine runs a research project involving teams from UK and France looking at 'shared control' systems for wheelchairs - think of it like riding a horse; you tell it which way, it does the job of (mostly) avoiding obstacles etc. The problems and challenges are non-trivial - even getting obstacle detection to work reliably in a home environment with varying hard and soft surfaces/material etc is a challenge; what works well to avoid walls and steer down a 1.5m+ wide corridor is all but useless to steer through a 1m gap between a sofa and a coffee table for example. And they've tried everything from simple ultrasonics, laser scanners, lidar, millimetric radar, machine vision, etc, etc. No one sensor technology works reliably in all environments.
gcebiker wrote:Irving wrote:@max71 While I applaud your thinking and determination this isn't something easily done. A colleague of mine runs a research project involving teams from UK and France looking at 'shared control' systems for wheelchairs - think of it like riding a horse; you tell it which way, it does the job of (mostly) avoiding obstacles etc. The problems and challenges are non-trivial - even getting obstacle detection to work reliably in a home environment with varying hard and soft surfaces/material etc is a challenge; what works well to avoid walls and steer down a 1.5m+ wide corridor is all but useless to steer through a 1m gap between a sofa and a coffee table for example. And they've tried everything from simple ultrasonics, laser scanners, lidar, millimetric radar, machine vision, etc, etc. No one sensor technology works reliably in all environments.
When learning to drive we are taught to look in the distance and our brains will figure out the rest, its triangulation. The closer we focus the sharper the angles become and the more sever our driving/steering correction's are.
If distance sensors were on each side of a wheelchair, a narrow 'field of view' and mounted on servo's, directed by a lidar.
....maybe two sets on each side, left side measuring the distance the left side of the obstacle and the left side measuring the right side to the obstacle and visa versa.
Creating double triangles.
Surely its just a maths problem to get the 'base' of the quad triangles to equal each other. To fit squarely though a gap.... ?
Burgerman wrote:JUST a mathematical problem?
The Mathematical Universe
NASA/JPL-Caltech/R. Kennicutt/SINGS
The history of mathematics is a history of humanity seeking to understand the universe. Therefore, many consider the holy grail of mathematics to be the same as that of physics: a theory of everything, a unified theory that explains all physical reality.
Regardless, mathematics could stand as humanity's greatest invention. It composes a vital part of our neural architecture and continues to empower us beyond the mental limits we were born with, even as we struggle to fathom its limits.
hatam1996 wrote:
Can I use Joystick Module
hatam1996 wrote:hi
I made control board
And used Joystick Module
But it didn't work
Please give me the code I want it to work with the joystick model
CAN YOU GIVE ME sketch Modified code PLZ
hatam1996 wrote:yes i have
I have already asked for help with this problem on the site
viewtopic.php?f=2&t=9046
I am now working on using the emulator to drive a Storm Arrow power chair with Brushless or 'GB' motors as Invacare calls them (Gearless Brushless)
stevelawiw wrote:@gcebikerI am now working on using the emulator to drive a Storm Arrow power chair with Brushless or 'GB' motors as Invacare calls them (Gearless Brushless)
Sorry I know nothing about your emulator, will you use the existing controller or perhaps RoboteQ? I've been trying to get RoboteQ and the GB Motors to play nicely, I was hoping there might be some common ground!
The present emulator i have built up for the Shark Controller will turn on the GB motors on the Storm Arrow Chair but not do any thing else.
I have yet to hook it up to the Logic Analyzer to see the data stream.
Users browsing this forum: martin007, Raro, woodygb and 145 guests
