Also, isn't charging at 10 A to high of a rate of charge?
Should the battery capacity be set to 68 (instead of the 55 it is currently on), or should it is set to 136 the combined total of 2 batteries?
Because the charger seems to be saying it is fully charged when it has only been on for one hour6, and even the wheelchair battery indicator says it is not fully charged.
I have 2 Odyssey PC1500R 12v 68ah batteries. The setup for the battery charging is wrong. Can you tell me where I'm going wrong from this video please?
https://youtu.be/T2O5WZCCEtk
You say;
Set capacity Ah to as high as it allows. Provided it still terminates at 100thC and I am guessing because that is not USER adjustable, and they used to base it on capacity.
How do I find out whether it still terminates "still terminates at 100thC"?
funkykeyboard wrote:This charger is the one you use now?
https://www.ebay.co.uk/i/223008081045?c ... kAQAvD_BwE
what is the PL 8?Burgerman wrote:And thats what we do with the PL8.
steves1977uk wrote:This is the Powerlab 8 (PL8 for short)... http://www.revolectrix.com/pl8_description_tab.htm
Burgerman wrote:Here is a SHIRLEY_HK power supply. Cheap, and as well as a 0 - 50A and 0 - 60V power supply (3000 watts) its also a completely configurable 3 stage charger. So good for lead batteries without any charger. At up to 50A if you want.
And a PL8... Itself being 40A and capable of properly charging lead, as well as lithium and anything else with better balance capability and config than the old hyperions.
Burgerman wrote:banghead
What will you use as a power supply for the PL8? Shirleys supply CANNOT charge lithium alone obviously.
funkykeyboard wrote:However, when I do a Google or Yahoo search for SHIRLEY HK power supply, I received no links to anywhere I can purchase this or even discussion of it???
So let me get this straight.steves1977uk wrote:That Fusion PSU is 5x LESS powerful than the Shirley PSU. It will work though, but you'll be limited to about 20A.
Users browsing this forum: Jay_x and 35 guests
