Invacare washers/spacers for rear wheels
Postby clairc » 24 Oct 2019, 20:53
Hi!
Does anyone know where I can get some washers with a notch cut in them like these? (Number 10 on the diagram)
My hubby bought me some new wheels for my Invacare Fox. The new wheels are for an Invacare Mirage/Spectra and we need washers or spacers to make them fit.
Thanks!
Clair
clairc
Re: Invacare washers/spacers for rear wheels
Postby duke1 » 24 Oct 2019, 22:12
hi claire when i needed same for my tinas chair i used these and just use a small file to cut the slot it just depends on size of the shaft it fits over mine was 20mm but some are different so best measure but this is where i got stainless ones,
https://www.ebay.co.uk/itm/M4-M5-M6-M8- ... d54dad5fb5
duke1
Postby clairc » 25 Oct 2019, 14:19
Thanks, duke1. Making the washers was our plan B, I just thought I'd ask to see if I could get hold of any first.
clairc
Postby Burgerman » 26 Oct 2019, 02:13
You probably could from invacare.
Postby rover220 » 26 Oct 2019, 08:04
Burgerman wrote:You probably could from invacare.
through a dealer if you supply part numbers, may have to wait a whilst though.
there is a minimum order value so may have to wait until a dealer is placing other orders
Postby flagman1776 » 26 Oct 2019, 15:42
This may be a silly question but unless the shaft key is stuck in the axle keyway, why does the spacer need to be slotted for the key? The key is unlikely to extend into the motor housing where it would interfere with seals. Why won't a correctly sized flat washer do? Does it matter if the spacer turns with the wheel, flanged adaptor, axle against the motor housing which doesn't rotate?
TravelScoot1 3P8S LiFePO4 Hyperion 1420i
TravelScoot2 OEM LI & charging
battery interchange adapters
flagman1776
Postby flagman1776 » 26 Oct 2019, 15:47
Google "notched washers" you will find them. Or arbor spacers.
flagman1776
Users browsing this forum: 7Gluk, duke1, Google [Bot], iainsherriff, loky, rickystyx and 45 guests
