rover220 wrote:yep there is a third party backrest frame available, i can supply if required.
probably younger than 10 years old aswell, production date will be on a sticker
terry2 wrote:I have got the Sedeo Seating on my Puma 40. It's very comfi and waterproof.
Be warned the motors for the Puma 40 will cost you a kidney and 2 legs.
rover220 » Yesterday, 07:16
hotwheels_75 wrote:rover220 wrote:yep there is a third party backrest frame available, i can supply if required.
Do you have pictures? I haven’t had much of a chance to investigate any of the details. It looks newer than 10 years, I’m only going by the people I got it from.terry2 wrote:I have got the Sedeo Seating on my Puma 40. It's very comfi and waterproof.
Have you had many problems with your motors? Good to know! I’m not using my legs but I still need my kidneys!
rover220 wrote:http://www.sunrisedice.com/asset-bank/assetfile/32780.pdf
page 67
hotwheels_75 wrote:Thanks for all the replies. I have a lightly modified MatrX Backrest, it has extra padding and some contoured areas for pressure relief for my bony back. It’s quick release and I can just swap it between my chairs.i could just see if there’s a sedeo Backrest that would suit me. The sedeo system is quite impressive with its ease of adjustability.
This chair has 6mp motors is currently in FWD, I really like that it’s reversible. It has the swing away leg rests but they’re powered. They appear to be kinda flimsy though. I plan to test it as FWD, I’ve only ever had RWD chairs. It has a power tilt with elevation, which I’ve been wanting to try out an elevating seat. It’s r-net but only a 90A controller. It has really skinny wheels and tires though which I’d definitely have to change if I end up using it.
Im in Canada too, so availability of some stuff might be more complicated/expensive to ship. I’ll look through the order form and check with my OT see if I can get a Backrest and not modify anything.rover220 wrote:http://www.sunrisedice.com/asset-bank/assetfile/32780.pdf
page 67
Can you give a price?
foghornleghorn wrote:Wouldn't surprise me if a lot of branded chairs are basically a crate of Chinese parts bolted together in a different country in the same way cars used to be skirt around tax and import laws by having final assembly done in the country of use from a set of pieces. Several big name chairs I've seen recently look pretty much identical to earlier Chinese offerings too, as if companies are just sourcing complete chairs from China and up-badging them, rather than the Chinese version being the knock-off copy.
Burgerman wrote:That IS for 3rd party brackets. On the puma chair.
As for oddball chinese chairs, they are what they are.
ex-Gooserider wrote:foghornleghorn wrote:Wouldn't surprise me if a lot of branded chairs are basically a crate of Chinese parts bolted together in a different country in the same way cars used to be skirt around tax and import laws by having final assembly done in the country of use from a set of pieces. Several big name chairs I've seen recently look pretty much identical to earlier Chinese offerings too, as if companies are just sourcing complete chairs from China and up-badging them, rather than the Chinese version being the knock-off copy.
Basically right - if you look into it, there are only a few makers for motors, chair control systems, actuators, and so on... So the chair makers are all getting their major parts from the same few places, many Chinese, some other countries....
The individual manufacturers may design their own frames and brackets, possibly a seating setup (unless they get the seats from the same few companies that make seats for the auto industry, which is likely on scooters and the less fancy power chairs) but everything that bolts onto them is coming from the same few suppliers
hotwheels_75 wrote:I tried to mount a solid 3.00 x 8 tire on the rim and there was no chance. There was at least a quarter inch gap between the rim halves
shirley_hkg wrote:https://www.google.com/imgres?imgurl=https%3A%2F%2Fi.ebayimg.com%2Fimages%2Fg%2F~eQAAOSwMhVcG2fN%2Fs-l400.jpg&imgrefurl=https%3A%2F%2Fwww.ebay.co.uk%2Fitm%2Fsunrise-medical-puma-40-wheelchair-Parts-Drive-Wheel-And-Tire-%2F132894263905&tbnid=FWqZjAQHmk8TrM&vet=1&docid=FsWmDr9DSCVGrM&w=300&h=400&itg=1&q=puma%2040%20wheelchair&hl=zh-HK&source=sh%2Fx%2Fim
Users browsing this forum: shirley_hkg, woodygb and 90 guests
