3. The LCD screen appears to be delaminating. There are small bubbles appearing on the screen. If I press on a bubble, it moves and changes shape a bit. No word yet on what NuMotion will do about that issue. And, yes, I have removed the screen protector:).
4. The casters flutter terribly when I go over even a small pebble at medium speeds. The wheelchair is nearly uncontrollable when this happens at high speed. NuMotion asked me to torque some bolts down from 17 ft lbs to 21 ft lbs. We did that, but it has made no significant difference. The flutter is getting worse. The service manual says the anti flutter devices on this version of the F5 are not adjustable. NuMotion is sending a mobile tech out to take a look at the problem, but they are not available for another month.
5. On my first real ride, when the wheelchair had about 1 mile on it, the LCD screen suddenly displayed a large power icon (circle with a vertical bar) that slowly faded from gray to green and back. I cycled power and it did he same thing. I cycled power again and it powered back somewhat normally, but it had reset my profile and mode. I made it home, but I lost confidence in the reliability of the chair. The NuMotion mobile tech will take a look at this when he is here in October.
6. Today, I went for a ride. I had planned to go about 9 miles. About 3.75 miles into the ride, the wheelchair slowed down and started surging. The turtle icon was flashing orange. At the same time, the power meter jumped from 4 yellow bars to just 1 yellow bar (there are 3 red, 4 yellow, and 3 green).
That is a lot to be wrong with a wheelchair that is less than 2 weeks old and only has about 20 miles on it. Unfortunately, the mobile tech they plan to send out to look at it is not very capable. He is a competent mechanic (as in turning nuts and bolts), but is new to wheelchairs. I have worked with him on several occasions in the 6 months and am confident he will be pleasant, but clueless. All the good techs I worked with at NuMotion have left the company (one transferred to another state).
swalker wrote:In November of last year my wheelchair van was stolen with my Permobil F5 wheelchair in it.
The van and wheelchair were recovered, but both had substantial damage.
My insurance company required that we try to repair the wheelchair. I have used NuMotion (a large US company) for buying and repairing wheelchairs, so they attempted the repairs.
After many months of delays and failed repairs, my insurance company finally decided to replace the wheelchair with a brand new Permobil F5. I have had the new F5 for just under 2 weeks and have had quite a few issued with it. I would appreciate insight, recommendations, and just plain old sympathy.
Here are the things wrong:
1. It is the wrong color. I have in writing that NuMotion will provide the correct color trim kit. Color is the least of my concerns, as I am not very fashion conscious. But Orange? Really? At least my wife likes orange:).
2. NuMotion furnished the wrong size Roho seat cushion. NuMotion has reviewed the order and agree that the correct size was ordered. They have verbally told me they will send me the correct size.
So, what do I do? I am confident that NuMotion will not be able to replicate the intermittent errors. I am fairly confident the mobile tech will tell me the flutter is normal (the F5 that was stolen did not flutter, but it had a different anti flutter arrangement). I am confident that NuMotion will eventually get the right color kit, replace the Roho cushion, and agree the LCD screen is delaminating.
It seems like they should take this hunk of junk back and replace it with a wheelchair that works! But, will that resolve the flutter issue? Does the new version of the F5 simply overheat more easily than the previous version (thus the flashing turtle)?
Time is of the essence. I have a limited window in which I can return the wheelchair. I will use up a lot of that window waiting on a mobile tech to show up.
Right now I am pretty frustrated. I have spent almost 10 months getting the wheelchair replaced and now that I have the replacement wheelchair, it is acting a lot like a lemon.
I appreciate your thoughts on this situation.
steves1977uk wrote:Same here BM, I have lots of spare parts that I can test and swap over with help from family and friends. Much quicker than relying on most "expert techs" who can take weeks/months trying to fix the issue, when I can have the problem fixed in hours to a few days at the longest.
Don't understand why most wheelchair users feel they need to rely on techs and having to wait months before the actual issue is resolved. Crazy! Parts can be cheaply had from eBay or direct from Curtiss-Wright/Dynamic as the main two.
Rollin Positive wrote:
Email me direct I can help you...
Timm@RollinPositive@gmail.com
His opinion is that the actuator and ICS issues are likely to be caused by incorrect programming. If so, it should be easy to sort out.
His opinion is that the power issue (power icon appearing) and flashing turtle are both likely to be an issue with the batteries, battery connection, and/or drag in the motors.
He indicated there is a possibility the ICS master module and/or the Rnet power module could be involved. There could also be some involvement of the wiring harness.
My opinion is that if he is right, the constellation of problems is beyond the ability of the local NuMotion technical folks to resolve.
I have also talked to the Numotion folks locally. They are investigating replacing the wheelchair. In the meantime, they are scheduling a time for multiple technical folks from NuMotion and Permobil to get together (some virtually) to diagnose the chair.
In the meantime, I think the chair is essentially unusable. I am concerned about damage that might have already been done to the motors in the 30 miles or so of test rides I have done so far.
steves1977uk wrote:Basically the "tech" guys haven't a clue! Send the chair to me if you want! I'd rip off the Permobil custom modules and replace with generic R-net parts and you'd have a 100% working chair, instead of faffing around swapping modules hoping it cures the issues.
Burgerman wrote:Dont use permobil.
when I call in with a question they find the exact part and sell it
snaker wrote:Can you tell us an example about what part they gave you and how much did it cost?
And is it possible if you call them now and tell them what swalker posted in this thread. Then come back and post the parts that he needs to 'swap'. I think that would help swalker fixing his NEW chair without waiting months.
No, they have a detailed file based off the serial number of each chair. When I called for help, and sometimes my DME, they were always just very professional and helpful. I mean my Street is something like 10 years old and still runs well. They would know things like the exact caster kits, foot rests, random screws I think. The parts were never inexpensive but were always the right part and always worked well.
Users browsing this forum: hotwheels_75, LROBBINS, Raro, slomobile and 21 guests
