Burgerman wrote:You can just measure across the 2 wires going to each cell.
snaker wrote:Does it have any docs that describe the communication to remote control or monitor cells (like the PL8's docs in the attached file below)? It's Ok in Chinese, I will read it through google translate
Looks like it is doing what it claims . Can set the balance kick-in volt .
Accurate too. All cells volt are indifferent , as I hooked up PL8 and showed the same .
Balance is kind of slow as it is doing ONE cell at a time , whereas PL8 is doing all 8 cells simultaneously .
Took different Ah out from several cells to make battery pack out of balance and recharge now. Log it with PL8 to see how good it will do.
If a mosfet fails shorted, trust me they do! All those balance wires melt their insulation and burn each other which then also short out.
You can't set it to 4 digits in normal mode BM.
Users browsing this forum: FrontierNZ and 15 guests
