Postby woodygb » 04 Oct 2020, 06:29
You have a private message.
Postby 11ydy » 04 Oct 2020, 12:16
woodygb wrote:You have a private message.
Thank you very much for your help!
11ydy
Postby takenaback » 06 Oct 2020, 02:45
I have a quickie explor 2 (Amysystems) and also the Sunrise EU OEM programming app, Rnet dongle etc. Was wondering whether there’s any possibility of enabling the chair to tilt whilst in lift mode. I can tilt forward whilst in lift mode and sometimes I need to do this but it won’t go back without me activating the lift mode almost fully down before I can tilt. Then I go up again, pain in the backside at the pub. Don’t know whether it can be adjusted but any help would be appreciated.
takenaback
Postby rover220 » 06 Oct 2020, 07:23
takenaback wrote:I have a quickie explor 2 (Amysystems) and also the Sunrise EU OEM programming app, Rnet dongle etc. Was wondering whether there’s any possibility of enabling the chair to tilt whilst in lift mode. I can tilt forward whilst in lift mode and sometimes I need to do this but it won’t go back without me activating the lift mode almost fully down before I can tilt. Then I go up again, pain in the backside at the pub. Don’t know whether it can be adjusted but any help would be appreciated.
Yes, have a look at the actuator inhibit settings. Be aware of risk of tipping, not likely but not impossible.
Postby takenaback » 06 Oct 2020, 08:55
No chance of one of these tipping, they've got an unusually big set of anti -tip wheels, caught between mid wheel drive and rear will drive. This is what I see on the programming app, I'm not sure exactly what to do.
takenaback
Postby shirley_hkg » 16 Oct 2020, 00:57
Can we get hold of programming OTTOBOCK chairs ?
① B500/B600(older)
② JUVO B5(newer)
Thanks.
Postby Burgerman » 16 Oct 2020, 05:54
I thought they were just PG Drives/RNET?
VR2 or "ten". Which is actually R-Net with a weird branded joystick pod. So they can pretend its their own.
Postby woodygb » 16 Oct 2020, 09:36
shirley_hkg wrote: Can we get hold of programming OTTOBOCK chairs ?
① B500/B600(older)
② JUVO B5(newer)
Thanks.
B500/B600 models feature all the
advantages: the VR2, enAble®40 and enAble®50
control units adapted to the needs of the user
along with their flexibility and modular structure.
Shirley ..ALL of the above have programming solutions we simply need to know what control system is on these chairs.
viewtopic.php?f=1&t=5488&start=150#p161033
Postby shirley_hkg » 16 Oct 2020, 10:34
Thanks .
How can we get the software ?
Postby woodygb » 16 Oct 2020, 10:36
Thanks .
Ask :thumbup:
Postby shirley_hkg » 16 Oct 2020, 12:07
:thumbup: Will do.
Postby woodygb » 16 Oct 2020, 12:16
You have mail with the info.
Feel free to get clarification on it's use.
Postby shirley_hkg » 16 Oct 2020, 13:32
Does it require any specific connector ?
Also , anyone know the JUVO B5 ?
Postby woodygb » 16 Oct 2020, 13:47
The EnAble series requires a specific proprietary 5 pin plug OR just 2 pins will work fine.
The EnAble50 ( pins 4 and 5 ) are CAN-H and CAN-L ...This model is programmed with a USB- CAN adaptor.
The EnAble40 ( pins 4 and 5 ) are TXD and RXD... This model is programmed using inverted TTL
Postby shirley_hkg » 16 Oct 2020, 14:12
Thanks woody. cheers
Postby takenaback » 18 Oct 2020, 01:26
The previous picture I displayed on this page was irrelevant as it wasn't showing actuator inhibits. What I'm wanting to do is to be able to lift and tilt at the same time without being restricted but I'm unsure of what inhibits it may be. So I have attached a picture, the channels that are not opened up have no inhibits.is it possible the lift and backrest under Sunrise medical is the one that needs to be adjusted? cheers Steve
takenaback
Postby Burgerman » 18 Oct 2020, 01:43
Send me a copy of the settings file.
Its hard to understand these things if you were not the one that set it up or wired/programmed it. But I will take a look. What actuator module is fitted?
Postby takenaback » 18 Oct 2020, 02:05
Thanks BM
OEM original.R-net
(4.3 KiB) Downloaded 462 times
takenaback
Postby Burgerman » 18 Oct 2020, 02:26
What is the module used?
I cannot see recline as all. Only tilt/lift/legs.
As an xperiment, try this.
OEM original.test.R-net
(4.33 KiB) Downloaded 422 times
Postby takenaback » 18 Oct 2020, 02:42
R-net PM 120
No recline just legs, seat and lift. Steve
takenaback
Postby Burgerman » 18 Oct 2020, 02:51
No. Which module for the seating?
Theres the ISM, usually ISM6. And SM. And the fancy one that does feedback positioning etc which I cannot remember the name of thats very uncommon.
Did you test?
And this. Test.
If the first one doesent do the trick, this one should as I disabled all the ISM6 inhibits on actuators only and have not even looked at chair speed inhibits.
Hard to know for sure without a chair to test it on!
OEM original.test2.R-net
(4.33 KiB) Downloaded 421 times
Postby takenaback » 18 Oct 2020, 04:18
Can't test till tonight Australian time when carer arrives and let you know what's seating module I have. Steve
takenaback
Postby Burgerman » 18 Oct 2020, 11:48
Try the 2nd one first!
Postby takenaback » 20 Oct 2020, 02:07
I've had a lot of difficulty trying to transfer the files to wheelchair. I'm using a dealer dongle and I thought I might be able to get around it by using the cheat sheet but every time it says that it's transferring across it doesn't. Even though it looks like it is but when I read from controller it's the same existing file there. I'm unaware of what my seating module is so any assistance to identify that would be appreciated.so the chair has leg tilt & extension, lift, tilt.Steve
takenaback
Postby takenaback » 20 Oct 2020, 05:02
Seeding module is one of these ISM 2/4/6L.
takenaback
Postby takenaback » 22 Oct 2020, 00:30
Thank you BM I finally managed to get a file across and I can tilt whilst in lift mode. cheers Steve
takenaback
Postby Burgerman » 22 Oct 2020, 01:02
I removed several inhibits from the actuators however. So maybe something you did want inhibiting is gone too. So check out carefully. Otherwise, all good!
Postby Grucha852 » 19 Dec 2020, 11:53
Hello,
Would anyone be able to send me the OEM or Manufacturing version of the PC PG Drives S-Drive Mobility Programmer software ?
Grucha852
Postby woodygb » 19 Dec 2020, 14:06
You have a P.M.
Postby Grucha852 » 19 Dec 2020, 14:27
Thank you so much! :)
Grucha852
Users browsing this forum: acid_coke, Bing [Bot], LROBBINS, woodygb and 101 guests
