Burgerman wrote:Larger front wheels mean you may have footrest/tyre issues. You need a centre footplate if you can use one. It will allow the thing to be made shorter, and seat moved back slightly. That will make it steer better, and skid less, be better going down a ramp.
Also you need to keep your seating position LOW for stability reasons in use. Esp with lighter lithium batts if you ever go that way. Otherwise well done! That seat lift tilt module costs the same as the full chair.
Burgerman wrote:Why fixate on solid or foam filled?
swalker wrote:Yes. Here is a video of what I think you are asking about.
https://www.youtube.com/watch?v=g3tjxjR ... l=Permobil
I have this on one of my wheelchairs. It works great!
RE: Powered center footplates - Can you get a footplate that can run up/down on a Z-axis? so when you raise it up, your knees come up? I could use that, for sure. I can't have it extend outward due to atrophy
Burgerman wrote:It doesent have to. All mine can be adjusted up down, or out (change angle) as I wish. Or both things together. Two seperate motors.
Burgerman wrote:If I wasnt stuck in bed I would do one!
Footplate just rises. And so do my knees... And it goes to floor too. ONLY up or down. Also can change angle should I want.
Moosh89 wrote:My current footplate is straight down from my seat. I'd like to have it move straight up and down without extending forward/outward.
Burgerman wrote:The black wheel is the same. Just a rattle can of matt black or satin black turns a silver rim into a black one in 10 mins free of charge.
Burgerman wrote:PM me for that software. You might want to ignore his advice on settings...
Burgerman wrote:Best to just go with the flow. I am 60. 20 stone. Drive like a lunatic, fall out all the time. Over the back, sideways, and every way possible over the years. I no longer care. Its just embarassing with the passing fire service stopping to rescue me from my own stupidity. Or being laid in the wet road for an hour as I forgot my phone the last time... I wheelied it as you do, and it turned on its side and crashed down. It actually doesent really hurn.
Users browsing this forum: DrewDigital and 109 guests
