rickystyx wrote:Thanks I will consider that or even half and half - I suspect that the inner part of the original wheel may be made of steel - it has brake drums but admittedly only for a hand brake so they may be alloy and I've not taken the wheel off yet (I've only had it two days) If they are steel I'd use them for the hub and simply bolt to them but if they are alloy I will certainly look at a taper lock system
rickystyx wrote:Yes it is just a case of setting the two inhibit settings to off Inhibits - Drive - profile 1 and 3
I'm not sure there is a need for a handbrake on a chair or scooter unless perhaps should you want to use it as an anchor for winching someone out of the mud in which case it would take strain off the motor brake - so I might leave mine in place as I intend using it on rambles with others.
Very happy with it now I've got the seat set up and the controls where I need them and everything working as it should.
Time for an adventure I think before changing the battery - just to get my range anxiety bak you know
rickystyx wrote:Here it is - and a copy of the file with it already done for you
Users browsing this forum: Google [Bot] and 1 guest
