stevelawiw wrote:
https://www.walmart.com/ip/4-Fans-12V-24V-1000W-Winter-Portable-Car-Heater-Fast-Heating-Cooling-Fan-Windscreen-Demister-Defroster/854991834
I had one of the ones that Burgerman uses and it died glowing white hot and then the coils melted
But I've had success with the one I've linked to, much quicker than dumping through a PL8
Watts = Volts X Amps, so 2000 Watts at 24V is a bit over 80 Amps. There are lots of similar heaters on Aliexpress, ranging from ca. 300 Watt to 2000 and for either 12V or 24V
Burgerman wrote:READ ABOVE!
Then read this.
I also connected a couple of fans. They run quietly. They remove the heat from those two coiled springs. Those are actually resistance wires, a special kind od wire designed as heating elements as used in kilns etc.
So now mine runs cool.
I added fans. Connected to the PLUS/MINUS end. These were once fans to cool PC memory, from an old PC. Re used. Now the thing stays cool. No danger of burning whatever its sat on. And in the background - you cant have too many PL8s...
Burgerman wrote:Look above.
Did you repair your dump yet? JOIN WIRES!!!
Fans are not essential!
Patient dog.
Users browsing this forum: Burgerman, daveonwheels and 16 guests
