As it slowly lets air pass. 3RD ONE !
What do you mean by ‘As it slowly lets air pass. 3RD ONE !’? Do you mean you bought 3 pumps of the same model? Why was that?
So I gave up on trying to get a perfect non leaky pump. And ordered those tiny one way valves instead. So that now THEY prevent air leaking back out from the pump. I should have done this to start with...
Burgerman wrote:Thanks both! Me too.
I forgot to add. Against all medical advice, NO dressings. They appear to be part of the problem.
steves1977uk wrote:Does any one know a place that sells wedged cushions? The cushion I have is flat at the back and raises under my thighs to about 25-30 degrees sloped angle.
Melissa tried making me one from an old foam mattress, but without the proper cutting tools it's hard to make a smooth cut. Any suggestions on foam cutting tools please?
My old cushion is about 18in wide by 17in length.
Thanks,
Thanks,
