Kaschperlpropper wrote: The picture of the control unit that you sent has a different connector arrangement than that of the control unit from me. Can this be the reason?
FrenchGuy wrote:Hello again,
If it's can help for me after changing the USB/RS232 adapter it's working find.
However I have made changing in the controller (increasing the speed of course) but the difference is not much.
May I send you the file with the new setting for some advice?
Thank you
Kaschperlpropper wrote:maybe someone could give me the ohmic values when I measure rows 1 to 7 ohmic on the circuit board from above.
Thank you for your help
woodygb wrote:Your program is already at it's limit as far as SPEED is concerned.
It is however possible to add a little more urgency to the acceleration, but as I have said, nothing extra to the top speed.
FrenchGuy wrote:woodygb wrote:Your program is already at it's limit as far as SPEED is concerned.
The Maximum Forward speed value change from 50 to 100 in Profile 2 -> no effect.
I also try to disable the Profile 2 in the Multi-function Inputs configuration with no success.
The maximum speed stay at 8km/h.
Any idea?
woodygb wrote:FrenchGuy wrote:woodygb wrote:Your program is already at it's limit as far as SPEED is concerned.
Any idea?
What make and model of mobility scooter do you have?
Maximum driving speed: 8 km/h (5 mph)
woodygb wrote:https://www.mobilitysmart.co.uk/invacare-leo-mobility-scooter.html?msclkid=5185e2247cea15a0f49d830e45334307&utm_source=bing&utm_medium=cpc&utm_campaign=Mobility%20Scooters&utm_term=invacare%20leo&utm_content=B%20%7C%20Invacare%20%7C%20LeoMaximum driving speed: 8 km/h (5 mph)
Your scooter is geared to do 8 km/hr and you CANNOT go faster.
Correct.Bad news so no trick available....
Users browsing this forum: Bing [Bot] and 54 guests
