Re: PINNED - Where to find everything powerchair related
Postby REPARACIÓN SILLAS » 24 Feb 2022, 16:34
Hello everyone, looking for prices on the web I found this place in Barcelona Spain, which I think has good products. I leave you the most current price list that I found. SEVTRONIC.COM I hope it works!
https://sevtronic.com/img/cms/SEVTRONIC_Tarifa_PVP_INDUSTRIA_2021(1)_low_1.pdf
REPARACIÓN SILLAS
Postby Scooterman » 23 Mar 2022, 12:45
One of me front lights has blown, it's off a Salsa R2.
I've proved it by unplugging both lights from the R-Net and swapping them over L-R.
I've not opened it up but but looking through the glass it looks to have a tiny LED perhaps soldered to a cct board?
I'm trying to source a replacement. Or alternatively I remember seeing someone in the forum with nicer mini-maglite type front lights. I need a pair of decent headlights when popping to the local shops on a winters evening.
The ones on the salsa aren't bad, but I don't like the look of them much. Any ideas on where I can source a replacement, or replace LED, or fit a cooler style of front light? 8-)
Postby Scooterman » 26 Apr 2022, 08:46
No longer required.
I've since abandoned fitting new front lights and now have a little COB led torch hanging on the armrest.
COB led's are brilliant, I never seen them before.
https://www.wilko.com/en-uk/wilko-ultra-bright-led-torch/p/0289469
Postby Scooterman » 26 Apr 2022, 08:53
front lights mount now new lifting points :dance
Postby CPguy » 04 Sep 2023, 21:40
Here you can buy motors with gearboxes (note that they offer R-Net plugs, Dynamic, Curtis and Anderson plugs): https://www.electrocraft.com/products/gearmotors/MPP36/
As of this post they have a 27 week delivery time! So order well in advance.
My rides:
2 Progeo YOGA (for traveling)
CPguy
Postby dixonm » 13 Oct 2023, 06:49
Does anyone know where to purchase this plug? It is the main power connector that plugs into the R Net Controller.
AWS- Certified Welding Inspector and Educator
Rolling thru this crazy life I live!
dixonm
Postby Burgerman » 13 Oct 2023, 06:54
You can order it from PG Drives I think. But you can more easily order it from any manufacturer that has an r-net or pilot plus or VR2 controller on any of their chairs as part of a short cable that is called a battery loom.
You also dont really need one. The stock larger sized blade connectors as used on lots of cars etc are a perfect fit and do not need the plastic part. Just heat shrink the connector.
I got a couple from some sunrise chairs from eBay. Battery loom for a "tango" and a "Salsa" chair. Just be careful as some have thicker looms, and 120A fuses and some less.
Postby dixonm » 14 Oct 2023, 17:19
Do you have a good source for the larger blade terminals. Thanks for quick response
dixonm
Postby Burgerman » 14 Oct 2023, 17:29
I think they are the 9.5 or 10mm ones, cant remember. I just picked up a pack from my local motorist discount shop. Where all the boy racers get their stick on tat.
Quick look on eBay fnds plenty of the ones I think they are. 10 (9.5) millimeter ones.
Dont crimp! Solder. Then use internally heat activated heat shrink.
https://www.ebay.co.uk/itm/152686724083
https://www.ebay.co.uk/itm/181022941024
https://www.ebay.co.uk/itm/132076481575
Postby dixonm » 21 Oct 2023, 20:31
I found these in the US. Made by Noble Wire &Terminal Springfield OR, 97478. Part # 534H
dixonm
Users browsing this forum: Andrey, woodygb and 79 guests
