Burgerman wrote:As long as you have at LEA...
...fixed current for a limited period once current drops to a certain point. (Rather than waiting 8 hours at CV to really low currents).
The ProSport chargers have independent charging banks, too bad they don't have the programability that the Victron ones have. I looked at NOCO and a few others, but they don't have the right charging profiles.
For long term storage, is it better to charge at 24vdc, or charge each battery at 12vdc? Victron has some chargers with multiple outputs, but I do not think they can be hooked up to batteries that are wired in series because the charger outputs share a common ground. Charging at 2x12vdc would require 2 chargers.
Max time (h) = 1.2 * DoD (Ah) / Avg. Current (A)
1) For calculating the max time for the bulk (CC) stage, what is DoD? I am guessing it is related to C/20 somehow.
2) For calculating the max time for the bulk (CC) stage, what is Avg. Current? I am assuming this is simply what I set the constant charge current to.
Should battery safe be disabled?
Is 60 mV/C okay for MK Gel? I also noticed that the nominal temp on the MK spec sheet is 20 degrees C and Victron uses 25 degrees C.
What do you set for Re-bulk?
Do you set absorption to automatic or fixed? How long?
Did I disable recondition properly?
Victron Blue Smart IP22 Charger - 24 Volt, 16 Amp
General MK Gel Charging Profile
Function: Charger
Charge Preset: Custom
Night Mode: Disabled
Charge Current: 16 Amps
Maximum Current: 16 Amps
Max Charge Current: 16 Amps
Advanced Settings: Enabled
Expert Mode: Enabled
Battery Preset: User Defined
Charge Voltage
Absorption Voltage: 27.9 Volts
Float Voltage: 27 Volts
Storage Voltage: 26.7 Volts
Recondition Voltage: Disabled
Battery Safe: On ???
Bulk
Bulk Time Limit: 8 Hours
Re-bulk Method: Constant Current ???
Re-bulk Voltage Offset: 0.2 Volts ???
Re-bulk Current: Disabled ???
Absorption
Absorption Duration: Adaptive or Fixed ???
Max. Absorption Time: 6 Hours
Tail Current: 0.5 Amps
Repeated Absorption: 45 days
Recondition
Recondition Current Percentage: 0.08 ??? I think this stage is disabled above.
Recondition Stop Mode: Auto, on voltage ??? I think this stage is disabled above.
(Max.) Recondition Duration: 1 hour ??? I think this stage is disabled above.
Voltage Compensation
Temperature Compensation: -60 mV / degree C ??? Is this accurate for MK Gel?
The configured charge voltage is related to a nominal temperature of 25°C and linear temperature compensation occurs between the limits of 6°C and 50°C based on the default temperature compensation coefficient ... as configured.
To compensate for battery temperature not at 20°C, subtract 0.005 V/cell for each 1°C above 20°C; add 0.005 V/cell for each 1°C under 20°C.
Users browsing this forum: Bing [Bot], Qvickster and 28 guests
