The Woody home built programming lead works as well as the PG Drives one.
I plugged it into the USB, it asked for the driver... I fed it that, and it installed on COM26 which will never work with the PG DRIVES OEM SOFTWARE. Because it goes up to COM 8 only!
No problem, I moved the USB/SERIAL port to 8 in device damager. And then choose 8 in the software. Works flawlessly
viewtopic.php?f=2&t=1947&st=0&sk=t&sd=a&start=20#p25337
