Rebuild BM2 green...
Re: Rebuild BM2 green...
Postby Burgerman » 30 Dec 2015, 15:54
Adjust and align...
Pic 1
Postby Burgerman » 30 Dec 2015, 15:56
Again... Line up motors, adjusting all roast joints ((c) jenny) (2nd from left, top, too long, etc)
pic 2
Postby Burgerman » 30 Dec 2015, 16:01
Rear battery door, hinges, etc, and replace top motor mounting bolts with thinner head ones to miss battery terminals by greater margin.
pic 3
Postby Burgerman » 30 Dec 2015, 16:02
From the rear, flash never fired so colours a bit wrong...
Postby Burgerman » 30 Dec 2015, 16:03
Rear quarter - distorted because I am about 12 inches away...
Postby Burgerman » 30 Dec 2015, 16:06
inside...
Postby hank » 30 Dec 2015, 17:29
Burgerman wrote:From the rear, flash never fired so colours a bit wrong...
Like this shot. 8-)
f55s bm1 clone.
quickie groove Brushless
BM3 clone
Foldawheel PW 1000 XL.
Postby Burgerman » 30 Dec 2015, 19:30
You can see the stainless steel door hinges used on the battery door! :lol:
For anyone skinny, building a narrow chair, you could still move the rear wheels 10mm inboard (each side) if required and then it will be under 25 inches total. I left the 10mm gap so I can later on bolt on 4.5 wide rims, and even lower profile 145 tyres. As soon as I can find a set this side of the Atlantic.
Postby Burgerman » 31 Dec 2015, 15:06
Seat plate/frame. Too much dump here, shortened, footplate mounts cut off, different mountings, and powder coated.
Postby Burgerman » 31 Dec 2015, 16:36
Which I needed on, because it lets me configure the battery in multiples of 8 to take the best advantage of the space available. This is ESSENTIAL to take full advantage of the lithium battery.
Max capacity I can fit (easily) is 120Ah. (80x 12cells). Because one of the great things about these headway cells, over the typical prismatic cells, (or lead) is that it can be configured to use up all of the available space. It need not be rectangular. Or even all in one place.
See below:
Code: Select all
One at a time.
Code: Select all
PL8 charger used.
More done! 30, only 50 to go!
Burgerman wrote:[img]
motoman
Postby Burgerman » 09 Jan 2016, 23:06
Everything would be ineffective!
Postby Burgerman » 15 Jan 2016, 15:36
Built, cells carefully selected into 8 identical groups, so that they have equal self discharge rates, capacity, etc.
And under test. Wiring will be tidied up and cable tied. This splits into 2 halves.
80 Cells, 120Ah, 3000 plus watt hours, all cell groups selected after 6 weeks for similar self discharge rates, and for Ah capacity. This is under test.
Postby Burgerman » 17 Jan 2016, 21:36
Tidied up...
Postby Williamclark77 » 18 Jan 2016, 00:23
Very nice! I wish I had known of those connectors before I did the Anderson and aviation plug connection to charge my 14s pack. It works fine but is three things to plug in. Simple enough but the aviation plugs are pretty annoying to get connected good.
What's the heavy red cable at the top for? The short one horse-shoe'd over. It looks to be making a parallel connection. I was wondering why it instead of a two hole plate?
Looks good! I'd like to see a real world range test when done.
WcMade.com - Get nearly anything you need made
Williamclark77
Postby Burgerman » 18 Jan 2016, 01:21
Part numbers, pictures of the correct connectors.
The battery is in 2 halves. Hence the link cables. Tried Anderson, has too much resistance and at 40A charge cell 4 shows 10mV too high... So solid cable link. And very tight bus bars. It even matters where you connect the balance wires. Can be 5mv difference from one end of a bus bar to the other...
Get it right and it looks perfect and the exact same voltage to 3 decimal places on every cell.
If you fit the cheap turnigy watt meter, you can find out ultimate range easily. With lithium as you already know, there's no Peukert. They run at full power to 99 percent. So you can measure actual Ah used, over a typical day, use your phone GPS to measure miles, and just do the maths. It will be within 1 percent. Range should be rather good. Lower current 6.2mph motors. Rounded profile 6 ply radial tyres have very low rolling resistance. Battery is lighter, chair is 100lb lighter. The stock chair claims an ISO 24miles from 56Ah Sonnenschein gel batteries. Which is bull but... With better tyres, less weight and a true 120Ah I should go at least 3x to 3.5x further. That's 75 to 85 or more ISO miles. Or real world about about 2/3rds that. We will see -- I am fat!!!
Postby flagman1776 » 18 Jan 2016, 01:30
I actually look at this connector... when I salvaged my generic China pack... was it 2+ years ago? Since I had already made up the Anderson output to the TravelScoot, I just reversed it as the main charge leads...
However, building a pack that doesn't get disconnected with every use, a single connector is so much cleaner.
What is the service life of the connector?
Is there a rule of thumb for getting the best balance reading?
TravelScoot1 3P8S LiFePO4 Hyperion 1420i
TravelScoot2 OEM LI & charging
battery interchange adapters
Pride Wrangler
flagman1776
Postby Burgerman » 18 Jan 2016, 01:39
Service life? Unknown. But I can soon fit another. Looks pretty well made.
Its quite heavy gold plated. But even when that's worn away I don't see much of a problem. If there is it will show on the graph screen as uneven balance? But its proportional, and so will adjust for resistance changes on the fly... Cells all look pretty well matched here to the 0.001V level! (This Shirley, is why we don't use a BMS!)
BM2 one (2 connectors, as a 6S and a 7S pack at once).
And an 8S 120Ah discharge shows why voltage tells us nothing useful... Temperature varies the voltage far more than discharge level:
First charge so not completely together:
Discharge testing my quadcopter battery, through same connector while testing (only 3 cell, and all 3 well matched, this is LiPo so different voltages:
Postby Burgerman » 20 Jan 2016, 20:51
More pics while it was in the kitchen... Bit of space.
BIG ONES!
Just ordered anti tip wheels (80mm black hard urethane inline skate wheels) and spacers, and bearings. And a 120mm M16 8.8grade bolt for the tie down. Those have to be fitted, tested for fit and angle befopre battery can be added as I cant get it up on the bed afterwards. Too heavy!
Postby hank » 20 Jan 2016, 21:19
Should'nt be far away now John. Looking well 8-)
f55s bm1 clone.
BM3 clone
Postby Burgerman » 20 Jan 2016, 21:23
Once the tie down bolt is in and the correct length, anti tips on, and battery in place then its all over. Just bolt the seat together. And then make a footplate (by a beermat drawing and a online laser cutter!) and drill a few holes etc to fit it. Then we can go for a silly mileage marathon!
At a narrow 24.6 inches wide its the same width as most 55Ah 22nf battery INDOOR/outdoor type chairs that use skinny tubed or rock hard flat free tyres with about 15 miles max battery destroying range like the Smaller TDX chairs, the Pride Quantum 600 and Edge chairs etc. Only with about 60 miles or 4x the range. And the ability to work properly outdoors without filling loss or the casters sinking in or high centering. Its also shorter.
Users browsing this forum: flagman1776, Google [Bot], ICEUK, Rod, wheelie junkie and 55 guests
