Burgerman wrote:Where?
Burgerman wrote:http://www.frogsisland4x4.com/wheels_and_spacers/batteries_odyssey/odyssey_batteryPC1500dt
Burgerman wrote:Basically all you said. Exept that groove motors really require 120A Rnet controller.
Burgerman wrote:You realise thats 10A + 10A at 24V? It wont charge your chair at 20A.
Burgerman wrote:I started doing a page here http://www.wheelchairdriver.com/powerchair-parts.htm
But kept getting sidetracked. So will link that page to this topic here.
So feel free to add links here. And to update and delete as needed.
Pride (overpriced) parts here in the US (Full parts and prices catalogue) http://www.southwestmedical.com/replace ... -mobility/
Sunrise (in the UK - There are others in other countries) http://parts.sunrisemedical.eu/uk/login/login.php use guest, guest for login/pass.
Give each post a new title so these links can be searched. And I will make this a sticky.
Burgerman wrote:http://www.trampaboards.com/
Caster rims
Burgerman wrote:I think their plastic rims are the correct width for those tyres and wider than the metal ones.
Burgerman wrote:Whatever rims you use they will need different axles/spacers/fasteners etc.
http://www.trampaboards.com/wheels-c-48.html all the top row, 7, 8 or 9 inch wheels are 4 inch diameter rims. But only the 3 spoke ones are really wide enough.
http://www.trampaboards.com/superstar-wheels-c-26.html metal centres, plastic rim, may be narrower...
http://www.trampaboards.com/9-inch-wheels-c-298.html plastic, should be same size / width as you use now. Maybe a fraction narrower but not enough to matter.
expresso wrote:http://www.trampaboards.com/9-inch-wheel--black-3-spoke-primo-hub--black-9-inch-primo-striker-tyre-p-10043.html
these looks great - would these fit the stock forks on the quickie chairs also - if i get the 9 x 3 forks - - seems like all the good stuff is over there in the UK -
cant find anything here - maybe its just me -
https://www.quickie-wheelchairs.com/rep ... 646-s646se
i would like black front caster tires also -
Users browsing this forum: Bing [Bot], iainsherriff, mrgus2u, woodygb and 82 guests
