frogsuk wrote:4. Invacare Storm 3 that is in snail mode again with an ACS controlerjoystick that I want to tweak so I can go up the woods in the village at the same 4mph as the Wheeltech instead of about 2mph.
I'm more than capable of making the cable for the R-Net but am having a real problem trying to get the R-Net software. I have a XP Panasonic Toughbook that I use for other vehicle related and programming software butI am getting pretty desperate now as I really need to alter the parameters of the Sectra as the only other chair I can drive from -"(- headrest) is the Wheeltech that is currently as mentioned above, dead
Please help
PS based is south west Wales, someone's got to be!
rover220 wrote:frogsuk wrote:4. Invacare Storm 3 that is in snail mode again with an ACS controlerjoystick that I want to tweak so I can go up the woods in the village at the same 4mph as the Wheeltech instead of about 2mph.
Please help
likely the magnet switch that controls the slow speed switch has moved causing that problem. join the 2 purple wires coming from the CLAM to permanently disable this issue.
woodygb wrote:Pic that may help if you take the pod apart ...it shows the location of a black locking oval pin that should be depressed to allow the board to slide out to gain access to the various activation pads on the reverse side.
memturbo wrote:yes read the articles tried to sign up 2 months ago thru that site did not approve my request can't download anything,
Would someone be willing to share their username/password ?
Found nothing about straight to serial connector just usb .
Squanto wrote:I have been a Lurker on here for a year or so, and finally bit the bullet and signed up!
I am building a modified chair like the BM3 but as Quicie F55 are like Rockin Horse Teeth, I have gone for a Kymco K-Active as my Base model - cheap too when new and still being made, chassis is almost identical to F55
Now I have several chairs all running on Penny & Giles controllers mostly VSI & VR2 which I would like to program.
Where can I get the Programming software preferably OEM version ???
I have got many FTDI & Chinese Serial to USB leads (from Arduino and model helicopter Gyros)
Many Thanks
Mark Squance
Plymouth, England.
Smitty62 wrote:Hello
can anyone point me to programing software for a jazzy 1100, Pilot Controller D49637
thank you
lakonas wrote:Hi guys,
I'm looking for the mobility scooter programming software for the Solo controller.
Thanks in advance!
Users browsing this forum: DrewDigital, Pierro and 42 guests
