funkykeyboard wrote:I think that is what you are saying. What size is the nylon washer on the Castor bearing nut?
Burgerman wrote: I don't get it with slightly lowered tyre pressures even at 15 or 16 mph. And the casters are free to turn. http://www.wheelchairdriver.com/BM3-con ... /15mph.mp4
Burgerman wrote:Looks to me like you have the caster barrel tilted at an angle because the rear is too high.
Wow, 15mph looks fast from that video.
HotColors wrote:Burgerman wrote: I don't get it with slightly lowered tyre pressures even at 15 or 16 mph. And the casters are free to turn. http://www.wheelchairdriver.com/BM3-con ... /15mph.mp4
Wow, 15mph looks fast from that video. And you are chin pressing a camera and holding a phone. Are you sure you are not a stuntman? Looks really smooth though.
Mike
Burgerman wrote:First lose those horrid front tyres they will likely always shake. The solid ones too heavy. The others are just nasty. Get some quality 3.00 x 4 ones.
Then don't raise the front, the CG is too high already. Lower the rear. Whatever that takes. Then find a really flat floor, and make sure that with about 6psi in the rear, and about 10 to 15 in the front that the load on each front caster is the same.
And make sure they run true. To a mm. And you may not think it matters but balance the caster wheels/tyres.
inglegrump wrote:The idea of adding washers to try and 'tighten' a bearing is nonsense. A bearing will only work correctly if the outer is a 'bearing fit' onto say the wheel...
Users browsing this forum: No registered users and 25 guests
