However it is possible to do oem programming with a dealer dongle. Just need oem software.
Is it?? I am not so sure! It just allows dealer access from memory.
Burgerman wrote:However it is possible to do oem programming with a dealer dongle. Just need oem software.
Mr.Math wrote:So if you have a DEALER dongle and OEM software, you can change ALL the settings?
How does that work? Do you open a file in the OEM software without the dongle connected, make changes, and save it, then plug in the dongle/chair, and push the file to the chair (as opposed to loading the settings from the chair, changing them, and writing back to the chair)?
I'm guessing you mean you can't read back what the current OEM settings are on the controller with the DEALER dongle so you can blindly write them and assume the changes happen, but can't confirm it one way or the other?
That would be a bit clunky, but sure better than not able at all given the scarcity of OEM dongles.
Am I correct in my understanding of what you two have said?
steves1977uk wrote:Check PM
hank wrote:steves1977uk wrote:Check PM
Top man cheers Steve.
rover220 wrote:hank wrote:steves1977uk wrote:Check PM
Wonder where Steve got it from!
Users browsing this forum: No registered users and 19 guests
