In the absence of decent suitable brushless powerchair motors, these types of reduction motors/gearboxes could be used. This shown will give more power and MUCH greater efficiency than existing powerchair motors.
That looks really good John the question is how do we control a pair in our chairs ?
JoeC wrote:An alternative that I have been investigating is the Golden BLT-800 motor. I have contacted the manufacturer for a custom winding, which should cost *far* less than the Astroflight. It won't be as light, and might only be 80% efficient instead of +90% efficient, but if it can be made to work with a single stage timing belt, then it will still beat the pants off of existing powerchair motors for overall efficiency.
The battery I'm making is a 56 cell pack at 14s using Headway 12ah cells. I could go 70 cell, but space gets tight. I'm also not too sure how long 24v brushed motors would last under my VERY demanding usage at 48v. I'm barely 140 lbs, but my chairs are pushed very hard.
Burgerman wrote:Why not use roboteq and just go 48v? Still possible to charge at 12v, parallel, and so on. There will be some efficiency gain too. And the roboteq allows up to 55v before it complains. It means better acceleration all the time not just at start up/stall.
JoeC wrote:It will probably work out. I'd suggest leaving yourself the option for a greater reduction, although I understand why you wouldn't want to (larger sprocket, worse wrap angles, etc), because if the torque isn't sufficient then your only other option will be to use two of the 150 amp single channel controllers, or to go through the pain of figuring out some of the Kelly brushless controllers, or....?
Burgerman wrote:You cannot use 14s with the roboteq.
14 cells fully charged is 14 x 3.600v or 50.4 volts. Now it MAY not complain but you have to consider the regeneration spikes above this point when you decelerate. That may cause it to see over volts and shut down. Its really designed for 36v lead systems. They are about 40v or so fully charged. The extra is headroom. This is the reason I went with 13s. And 78 cells. or 3k watt hours. That's 47v charged. Leaves a few volts spare!.
Burgerman wrote:For a SMOOTH brushless you need about 25 poles on the motor or more for direct drive. So about 8 poles on a 3 to one gear ratio. So it may be better to use 6 to one, and use a lower impedance motor. They all hesitate at a start, because until they move they don't know which direction they are going to go. The more poles the better, and it must be sensored.
Users browsing this forum: Burgerman, denis.b, jefferso, shirley_hkg and 721 guests
