woodygb wrote:The make and model of the control system attached to your ...or any wheelchair ...is the information that is required to provide you with the correct programming lead ,the relevant software and appropriate guidance to go with it.
So ...Can you post a picture of your joystick.
woodygb wrote:The first pic is a Penny and Giles Vsi 4 key.
The second is a Dynamic DX2.
The programming lead will have a switch to toggle between the 2 types.
Woody is fine ..
gcebiker wrote:woodygb wrote:The first pic is a Penny and Giles Vsi 4 key.
Woody is fine ..
Second is Dynamic Shark
yep you bad lolgcebiker wrote:My bad, should have blown up the picture.
wheelchairer wrote:Hey Woody, do you sell these as well?
Has anybody built one of these, A XLR phone charger?
Do you have a parts list, and wiring design?
shirley_hkg wrote:woodygb, what is the proper connecting steps ?
I have the USB converter installed.
Plug in your lead. Joystick shows an inhibit.
Connect the other end to USB converter. Inhibit goes away. Is it normal ?
Launch Wizard, but see it is not connected yet.
Any advice ?
OK. Will check on it and return back . Thanks.
Dynamic and the lead from you.
Users browsing this forum: No registered users and 24 guests
