R-Net Control Module D50903.14
Postby Arima » 04 Nov 2020, 19:00
In case someone is looking for one of these. The tag says 120amp. Seems like a good price as they frequently list for $299.
https://www.ebay.com/itm/133565643229?ul_noapp=true
Thxs
Arima
Re: R-Net Control Module D50903.14
Postby Burgerman » 04 Nov 2020, 21:55
That the right price.
Also, you should read here:
viewtopic.php?f=2&t=8857
Postby Arima » 05 Nov 2020, 00:48
From what I have seen that is a fair price for this market. You have a much friendlier consumer environment...even with all your socialist. At the moment the next best price on ebay in the us is $149. It's a different part no. and from a permobile.
https://www.ebay.com/itm/PG-Drives-Perm ... SwCe1foYkp
Is there a difference between part D50946.17 and part D50903.14? Let me guess the firmware again... Can the power module be flashed to generic R-Net? This has probably been answered before put I to grumpy to search for the answer. Plus I don't have a version of the software to flash.
Thxs
Arima
Postby Burgerman » 05 Nov 2020, 08:24
As far as I am aware, all the power modules have similar firmware. The different numbers just refer to the programming - preset for a specific chair. So that they become plug and play. No need to own OEM programmer to configure things like voltages, directions, compensation etc.
The generic non programmed ones are cheaper. Once you copy your settings file, or configure from scratch, then they are the same thing. As far as I have been abe to tell. I have permobil one here and it works like all the others.
Postby Clif » 09 Nov 2020, 17:32
I was able to pick it up for $100 !
Clif
Postby Burgerman » 09 Nov 2020, 19:38
If you are PATIENT then its all possible super cheap. When they appear cheap on eBay they vanish VERY fast!
Have a read here:
You never know when the availability of GOOD control systems or spares for one, will dry up. Or be locked down so that we cannot properly proram them on future chairs. So I am future proofing.
JOYSTICKS 6
I have a cheap as new LED joystick, 3 factory refurb (basically new with screen protectors) Advanced Colour Joysticks with infra red and one has BT. And another 2 on my Salsa chair and my new Q700R chair.
POWER MODULES 5
All 5 are 120A. As new or factory refurbs. Or fitted to the Salsa and the new Q700R chairs.
SEATING and LIGHTING MODULES 5
I have 2 ISM6 fitted to the Salsa and Q700R chairs, and 3 spare ones, as new, and a complete set of full house wiring looms.
BUS CABLES
Bought about 10 all different lengths. And 4 more already on the Salsa and Q700R chairs.
IOM MODULE
I have 1 for RC use.
I have a bunch of other parts like the bus cable connectors and multipliers, OEM programming dongle, remote joystick (attendant).
I didnt pay much for any of it. Some months maybe even 10 months its all way overpriced. Other times its cheaper. Mostly it vanishes fast if its cheap! So you never see it. You need to monitor daily. Or ask on here. I got some cheap in here too.
Postby JiniEdmus » 31 Jan 2022, 17:47
Hmm, 300 dollars for it seems to be a good deal. The last time I found one on Amazon, it was more than 500 dollars, and I thought it was a reasonable price.
JiniEdmus
Users browsing this forum: No registered users and 17 guests
