by Martin O Refurbisher » 28 Jul 2011, 08:25
F55 Hubs & wide wheel spacers No 2. Allows fitting of 145/70 x 6 wheels, 3 hole, 88 mm PCD.
The two hardened grub screws which lock into the 6mm keyway are 6 mm, and must be tightened to 200 inch pounds.
Here are our hubs to convert the standard parallel F55 EMD motors to take the wide wheel adaptors / spacers
Best,
Martin
- Attachments
- IMAG0254.jpg (41.43 KiB) Viewed 3164 times
- IMAG0255.jpg (41.32 KiB) Viewed 3163 times
