Burgerman wrote:What size is the small barrel connector on the front ? Or voltage sensing at the battery?
Voltage probe when using the 4-wires mode.
You run a calibration to let it measure resistance of the wires.
Burgerman wrote:What size is that barrel connector?
Burgerman wrote: Just the top.
Burgerman wrote: I will take that one.
c500user wrote:I have been looking for a lab power supply with a bit more grunt than I now have. The ZXD certainly fits the bill and 60V is enough for what I plan to use it for (amplifier testing). The problem however is I usually need a symmetrical psu, so 2 independent rails of say 25V and -25V.
Some switching power supplies are totally isolated, so the output is truly floating. This means you can use one to provide 0V and 25V (black and red) and the other to provide -25V and 0V (black and red).
Power supplies that are not floating however, do not allow this, because you are connecting RED from one psu to BLACK from the other. If you do this with non-floating psus, expect some fireworks.
Is the output of the ZXD floating? If so, can you let me know the price for 2 units (HKD or EUR) + postage to Australia?
Users browsing this forum: No registered users and 233 guests
