Burgerman wrote:I dont know where to begin.
I would remove all that plastic because it will likely get just as wet under the plastic anyway as water and snow will run everywhere. And now it cant dry out easily or be rinsed with water and so the salt is trapped. It will not stop anything rusting or corroding. May even make things worse. The casters will throw salt up the other side of that "wall" and cover everything...
HI which plastic do you refer too? the kitchen cutting board or the 500 ml pot on the end of the motor or the 1Liter pot lightly open ?
Burgerman wrote:Stainless frame...
This is aluminium, easy to make something in stainless instead.
Stainless bolts with stainless nuts or threadded parts can friction weld to each other seemingly for no reason..
Users browsing this forum: acid_coke, c500user and 51 guests
