which chair is best or better.
Re: which chair is best or better.
Postby carlo67 » 20 Jun 2015, 02:48
I like programming chair and speed profiles.
Can I adjust these options.
Forward Acceleration
Reverse Deceleration
Turn Acceleration
Turn Deceleration
Forward Speed
Reverse Speed.
Turning Speed
carlo67
Postby Burgerman » 20 Jun 2015, 10:44
Turn Acceleration
Turn Deceleration
Forward Speed
Reverse Speed.
Turning Speed
This is for sport/better control?
You also need:
MIN TURN ACC,
MIN TURN DEC,
MIN FORWARD ACC
MIN REVERSE ACC
MIN TURN SPEED
All these WILL need to be set to 100 too.
Or it will still feel delayed and inaccurate much of the time when you are not at exactly 100 percent full stick movement.
You may also want to increase motor compensation slightly. WITH CARE! A little at a time. To make it less smooth but respond more instantly.
And increase temperature roll back, to 70C from 55C to stop it reducing power.
And increase stall time, and other current related reduction setting to max or longer.
Because once you get it to jump and move you will run into heat and current rollback problems.
Postby carlo67 » 21 Jun 2015, 01:30
I know all this because I done it with my chair now
I need to have programmer and dongle for PG Drives R-Net
carlo67
Postby Burgerman » 21 Jun 2015, 02:26
Yes... Or find someone local like a dealer that does.
Postby carlo67 » 21 Jun 2015, 03:16
but they won't sell it to me lol
carlo67
Postby Burgerman » 21 Jun 2015, 08:35
Same problem we all have. You have to "find a way"...
Postby carlo67 » 25 Jun 2015, 04:54
can anybody help me please
carlo67
Postby carlo67 » 09 Jul 2015, 08:14
carlo67
Postby steves1977uk » 09 Jul 2015, 09:30
That 's for Dynamic controllers, thought you were looking for a PG Drives R-Net dongle?
Postby carlo67 » 09 Jul 2015, 10:21
I am sell my Dynamic Wizard PC Programming Tools. do anyone want to buy it??
and I found seller who can sell the PG Drives R-Net dongle
carlo67
Postby Burgerman » 09 Jul 2015, 11:33
Can you share a supplier for others?
Postby carlo67 » 09 Jul 2015, 11:59
carlo67
Postby Burgerman » 09 Jul 2015, 14:46
That place will supply some people, not others. They should supply you as its for sport use.
Postby steves1977uk » 09 Jul 2015, 18:15
That's the place I got mine from, but another member on here had trouble getting one from them as they wouldn't sell one to him, so he had to visit me so I could set it up better for him. Guess it's how you explain what you need it for.
Postby carlo67 » 13 Jul 2015, 05:49
hi
I have a question
I would like to know what I can do with programmer?
carlo67
Postby Burgerman » 13 Jul 2015, 08:55
After sayng that you need a programmer, and want to adjust many things, for dozens of posts and pages of threads, now you ask why you need one?
Postby carlo67 » 13 Jul 2015, 09:31
I am wondering if I change the speed settings on the controller on chair?
like making my profiles?
carlo67
Postby steves1977uk » 13 Jul 2015, 15:12
Yes you can set up different profiles and speeds, but BACKUP the current setup before changing anything!!!
Postby Burgerman » 13 Jul 2015, 15:15
Postby carlo67 » 14 Jul 2015, 00:20
thank you for that
question
can I make chair to faster with programmer?
carlo67
Postby Burgerman » 14 Jul 2015, 00:28
Faster accelerating? Probably.
Faster speed? ONLY if the manufacturer or a subsequent user has reduced speed for some reason.
Why?
Because haviong a chair that is capable of more speed, but is deliberately programmed slower, totally wastes battery power by the same amount at EVERY speed.
If a manufacturer wants to reduce speed by 50 percent for e.g; then the best way to do that would be to decrease gearing by this amount. Or waste a load of energy for no good reason.
Postby carlo67 » 07 Dec 2015, 04:17
hi
guess what they mass up the order lol they ordered the All Terrain not Hybrid geez idiots lol
but they will changed from the All Terrain to a Hybrid. I will have my new chair in January
I got a question
Is Hybrid's tyres bigger? I would like to have bigger tyres on Hybrid ?...
carlo67
Postby Burgerman » 07 Dec 2015, 11:21
Hybrid?
Postby carlo67 » 08 Dec 2015, 02:04
yes I am getting the Hybrid. :D
carlo67
Postby Burgerman » 08 Dec 2015, 02:33
He means, Magic mobility V6 in case you are as bewildered as I was...
Postby carlo67 » 23 Jan 2016, 05:28
hi again its me.
I saw my new chair [Hybrid] last week it nearly ready for me.
I have a question.
I found this http://marketing.sunrisemedical.com/Tec ... mming.html
I am getting the R-net Omni. do I need the R-NET pc programmer stil ?
carlo67
Postby steves1977uk » 23 Jan 2016, 13:08
For OEM access you do need the OEM dongle and PC software to be able to set it up correctly. OBP just gives the user dealer level access.
Postby carlo67 » 24 Jan 2016, 00:08
hi
thank you
where I can get a OEM dongle ?
carlo67
Postby steves1977uk » 24 Jan 2016, 01:14
Postby carlo67 » 24 Jan 2016, 02:49
hi
thank you
I have a technical guy as good friend
he think he can make OEM dongle. can he ?
I already have PG R-net PC Programmer (OEM ver)
carlo67
Users browsing this forum: No registered users and 134 guests
