Sinopoly Cells - Info -
Re: Sinopoly Cells - Info -
Postby Burgerman » 03 May 2018, 15:06
Model name SP-LFP100AHA
Nominal voltage 3.2 V
Capacity 100 AH +/- 5%
Internal resistance <0.7 mΩ AC1kHz (5.6mOhm for 8s and no peukert so good.)
Operating voltage min 2.8V - max 3,65 V
Discharging cut-off voltage 2.65 V The cells is damaged if voltage drops below this level
Charging cut-off voltage 3.7 V The cells is damaged if voltage exceeds this level
Recommended charging - discharging Current 33A or 0.3 C
Maximum charging current 200A or 2C
Maximum discharging current 300A pulse or 3C
Life cycles ≥ 2000Times at 0.3C, 80% DOD (Less if discharged faster).
Operating thermal ambient- charging 0°C ~ 45°C
Operating thermal ambient - discharging -20°C ~ 55°C
Storage thermal Ambient -10°C ~ 45°C
The battery temperature should not increase this level
Shell Material Plastic flame retardants
Dimensions
142 x 61 x 221 mm Millimeters (tolerance +/- 1 mm)
Weight 3,1 kg
Postby shirley_hkg » 06 May 2018, 13:30
Seem like we can fit 16 of this 90Ah cells in G24 compartment .
131*37*200mm
@£30.00 :bounce
Postby Burgerman » 06 May 2018, 14:12
What would the total price with shipping be for the UK?
131 X2 IS 262 Wide. So with 2mm of insulation, at sides and between thats 262+6 wide. So 268? That may not fit.
Will need careful measurement. But 180Ah would be great. Esp for 480 uk pounds!
Postby foghornleghorn » 06 May 2018, 15:00
Do you not get hit by vat and duty importing from china? When I ordered stuff for my ventilator from USA by the time it was delivered it seemed to be twice the original cost :cussing
Postby Burgerman » 06 May 2018, 18:20
Approx 1/3rd of the time for large packages. From the US every time.
You can appeal and argue, and win if you are stubborn. Or accept the risk and just pay it.
But so what? Look at it like this.
2x lead bricks, MK gel rated at 73Ah, but only give half that at the 3 hour rate. will cost you £440 delivered. https://www.discountscooters.co.uk/73ah-mk-gel-battery
So you get a usable 40Ah to 45Ah at very best before you stop. Thats £9.50 per Ah, and they will be knackered in a year...
180Ah lithium, is going to cost you at WORST if caught by customs for VAT, £480 plus 96 vat. Thats £576 plus delivery charge whatever that is. Every 10 years or so.
And with 180/45 = 4x the range! 10 times the service life, half the weight, 7x faster charge, etc. And thats only £3.20 per Ah so ONE THIRD the cost of lead. Not including delivery.
In other words you would need 8x lead MK gel batteries to give the same range, but with 10x shorter service life.
Postby LROBBINS » 06 May 2018, 18:46
To me it looks like 8 of these would easily fit in the space of one Odyssey P1500:
Postby Burgerman » 06 May 2018, 19:02
On the face of it. But remember that these are metal shelled cells. The case is negative. You must seperate them, and be sure no metal can contact the ends/sides. So you need seperators, and a bottom, and 4 sides. 2MM plastic ABS or similar and double sided tape will do this. But it adds some size.
Also many chairs like my new one and the storm 4 chair, have exact fitting 260 x 173 x 210 battery areas. And metal!
So every case may need a little careful measurement and planning. But if you currently use Odyssey they should fit.
Postby expresso » 06 May 2018, 19:44
Most i know are fitted for MK Gel kind - My 646 did not fit the PC 1500 - frame is metal - to be 100% they have to fit when all said and done in a group 24 MK Gel size battery area - sounds great to have that much in a chair and the cost is also great considering -
just have to do the math and have it all planned out long before jumping in. since this 90ah is close - maybe if it can be found a 75ah - of same brand or company etc, may be just whats needed to get the fit most need. and still 150ah isnt bad at all - i wish i had that inside the chair.
Postby Burgerman » 06 May 2018, 21:18
I would probably order a set.
If I knew how, where from, and total cost delivered! :cussing
They are these: http://www.evlithium.com/LiFePO4-Battery/472.html
Postby expresso » 06 May 2018, 23:53
Burgerman wrote:I would probably order a set.
oh in that case - you can contact them and arrange it - much better than the webpages that we cant understand at all
Postby Burgerman » 07 May 2018, 00:10
Maybe! But they have now easy buy button...
Postby expresso » 07 May 2018, 00:21
yeah i know strange - teasing us :lol:
they do have a 75ah version but its too thick - wont fit - you would think it should be a bit thinner than the 90ah but its the same size - in that case better to get the 90ah -- if you can make it fit -
Postby expresso » 07 May 2018, 00:38
it wont fit in same size as MK Gel 24 - Sinopoly is 61mm thick - 8 of those fit -- to fit 16 of these 90ah - they have to be no more than 29mm to 30mm size at most. unless i am missing something -
Battery Dimension
200 x 130 x 36 mm
Postby Gnomatic » 07 May 2018, 02:16
shirley_hkg wrote:Found these good cells , and good price .. Reviews from buyers are ALL positive .
0.3mΩ rated @5C . 75Ah@£20.
May fit 16 of them in a G24 space . cheers :clap:
Hurry , while stock last .
Shirley, can you still get these @£20 per cell?
And shipping still 21 --- 44 kg @ £5.8/kg , plus £55 hazard charge? (If I get they will be shipped to US)
Those cells are indeed getting excellent reviews. I'm interested if available. I can fit 16 of them, with proper insulation, into my chair's battery area easily.
Also, does seller offer connector bars for those cells?
Postby shirley_hkg » 07 May 2018, 03:06
Yes . Still available .
Will be on holiday to Seoul for a week .
Policy always changing . Have to re-assure shipping when came back.
Hope to get sin85's OPTIMUS a 270Ah block , so he can ride all day long with his grand daughter .
drunk2
Postby Gnomatic » 07 May 2018, 03:39
Thanks shirley. Will check back in a week. Have a nice time in Seoul. :thumbup:
Postby snaker » 07 May 2018, 03:46
shirley_hkg wrote:Hope to get sin85's OPTIMUS a 270Ah block , so he can ride all day long with his grand daughter . drunk2
He can ride to ... the heaven cheers
Postby Burgerman » 07 May 2018, 09:35
I would have a set of those too. Again, if we had a price inc delivery!
Postby shirley_hkg » 07 May 2018, 11:56
Don't worry . Plenty of supply of this 90Ah cell . Even new stock too, that sells for doubled price tag. :dance drunk2
Postby Burgerman » 07 May 2018, 12:07
Its old?
New better...
Anyone gotpower supply yet? :|
Postby shirley_hkg » 07 May 2018, 14:02
cheers NOS is good enough . Of course you may pick the best .
PSU left 3/4/2018. In transit .
Postby Burgerman » 07 May 2018, 14:07
LiFe has approx 10 year shelf life. At the end of 10 years they are expected to be at 80% rated capacity, and int resistance doubled.
If they start off 5 years old, then you only have half the shelf life remaining... So how old is new old stock?
Postby steves1977uk » 07 May 2018, 14:14
Still waiting for mine too BM! :cussing
Postby Burgerman » 07 May 2018, 14:24
Postby shirley_hkg » 07 May 2018, 14:24
NOS unused stock made in 2014 .
Postby Burgerman » 07 May 2018, 14:25
So 6 to 7 years left...
Postby Gnomatic » 07 May 2018, 15:49
I'm willing to roll the dice on those NOS 75Ah cells. Lots of reviews and very positive. One reviewer got a set of eight and tested each, said six measured 80Ah capacity and the other two 83Ah. That's anecdotal of course but reflective of the positive response that particular cell has gotten.
My chair can't fit Odyssey batteries so those 90Ah cells are out of the question for me.
I'm still waiting on the PSU to arrive as well. Two months and counting LOL. Ship captain must be drunk2 .
Postby Burgerman » 07 May 2018, 18:48
I never saw any cell that gave more than written on the label. At least not without OVER discharging beyond the sensible limit. I have seen lead that does, as they generally give less initially, say 95%, and it climbs to 105% or higher, for say 20 or 30 cycles as it gets properly formed in use. Before tailing off.
So likely the person claiming 83Ah from a 75Ah lithium is likely to have no accurate method of testing. And/or doesent understand how to do it correctly. But at the price I am tempted to test one too. I would order 17, and test the one with the highest self discharge rate. Then would use the other 16 in a pack. Because a COMPLETE 100% discharge is likely to do some damage if you are unlucky.
Postby Gnomatic » 07 May 2018, 20:08
I understand what you are saying. And any single review should be taken with a grain of salt. The point I was trying to make is that particular cell has lots of reviews and they are positive, pretty much every one.
So would you expect the cell with the highest self-discharge rate to have the least capacity?
I'm thinking of ordering 20. Using the 16 cells I like best for my chair pack, and the remaining four cells can go in a 12v power source box I'll make up for them.
Postby Burgerman » 08 May 2018, 00:06
No. But its likely to be lower than average, and its the cell I wouldnt include in a pack.
Users browsing this forum: faico_26, jefferso, shirley_hkg and 466 guests
