Burgerman wrote:Did you notice that its those with the least technical understanding that cant understand how aything works that have the most "opinion"?
In 2011, Dunning wrote about his observations that people with substantial, measurable deficits in their knowledge or expertise lack the ability to recognize those deficits and, therefore, despite potentially making error after error, tend to think they are performing competently when they are not:
"In short, those who are incompetent, for lack of a better term, have little insight into their incompetence—an assertion that has come to be known as the Dunning–Kruger effect". In 2014, Dunning and Helzer described how the Dunning–Kruger effect "suggests that poor performers are not in a position to recognize shortcomings in their own performance".
I have given up trying to explain what to me is blindingly obvious. As simple as 2+2.
Arima wrote:
Ordered the ISDT P30 as I was looking at a smaller ISDT model before BM mentioned the big one. I'll be happy to share the results when new cells arrive. Hopefully it will help ease the pl8 anxiety.
not going to work unfortunately as each cell might take many hours.How about 8 single cell charges?
Burgerman wrote:You need to balance the pack every charge. Unless you KNOW it was in good balance already and DO NOT fully charge it. And only do that a few times max.Terry, what's the balancing current on the OverkillSolar BMS?
Only a tiny 80mA according to shirley, and only then if its a long way above the correct voltage. So its useless on a big pack. Esp if less than perfect/new. And already balanced by something else first. Hence he big list of warnings. But its got BT and nice graphics!
steves1977uk wrote:This one looks interesting... https://github.com/Green-bms/SmartBMS
Burgerman wrote:All those like terry2 or fred005 who remain completely clueless are welcome to use their BMS. They work in EXACTLY the same way, and cannot be improved no matter how many add on adjustments and fancy graphics they pile on. And the fact that you are incapable of understanding that shows your ignorance. But I am trying to educate not stop you. I couldnt care less about your battery oryour risk if you dont.
80mA balance!Same as my laptop.
Its like trying to teach physics to my dog.
steves1977uk wrote:So it's basically useless without a proper charger that can do 1A+ balance current? In other words, it'd take DAYS/WEEKS to balance a 210Ah pack which defeats it's purpose on a new build.
terry2 wrote:steves1977uk wrote:This one looks interesting... https://github.com/Green-bms/SmartBMS
I can't get in to the android app to see as I don't have the BMS
https://github.com/FurTrader/OverkillSolarBMS
Process set-up – charging Pb cells
Settings for lead batteries are very similar as to the LiXX batteries, and because of that only the differences will be
described below.
Setting the balancer is not an option as far as lead batteries are concerned. Fast and Reflex modes have similar
advantages as in the case of LiXX batteries. The final charging voltage „Vc“ can be changed between 2,25V/cell
and 2,55V/cell. When the value reaches the one suggested an exclamation mark will be displayed (! Vc).
The charging process will end when the final charging voltage will be reached (1/5 of the set charging current or
100mA – the lowest charging current possible)
Burgerman wrote:What will be important there is if its possible to set a termination current in mA that is user defined. Rtaher than being some percentage of charge current. And if it can be set to balance only above 3.50V. And not terminate until balance ends. Those are the critical things. And that it doesent have 101 safety guards and traps to trip us up. It may be OK. I think that shirley was looking at them too.
shirley_hkg wrote:terry2 wrote:steves1977uk wrote:This one looks interesting... https://github.com/Green-bms/SmartBMS
Burgerman wrote:Shirleys drunk again. But posted a blue spec sheet.
That BMS which is the same as the Overkill Solar marketed version, lets your cells reach 3.75V plus or minus 0.03V and 1 second (so likely nearer 3.85V) before cutting off all charger power with its on/off overvoltage switch. Then it uses its totally feeble balancer of just 50 to 60mA to drag it down to 3.5V. (best of luck with that!) Then it adds the charger full power as it cant throttle it and does it all over again. And again. So its EXACTLY as I said. Only its even worse! At least the cheap nasty ones like the one on my dell laptop battery (all 3Ah of it) has a 100mA balancer!
Burgerman wrote:I know what it is. I was sayiing there are NO lifepo4 replacements that are ever going to be reliable or worthwhile.
Many of us on here, including myself for a decade, have been using LiFePO4 for power. It can when done corectly give 10 years plus lifespan, and 4 to 5 times the range. But a lead brick replacement such as the ones you linked to wont allow any of that.
LROBBINS wrote:Fred,
I read through that entire manual and did a search for balance current. Much of the manual is pretty sensible, but I found no mention whatsoever of balance current. If I recall correctly I had long ago looked at a pic of the board and saw that the resistors used for balance were very small SMD (at most 1/4 Watt, more likely 1/8 or 1/10) so the balance current is necessarily tiny. Hence their insistence that you manually top balance the cells (a good idea in any case). This may work out OK in a solar panel backup installation where continuous discharge rates are fairly low and fairly constant. It will not work well in a char with very high and variable discharge currents - with the high current, cell differences, e.g. internal resistance differences, will cause larger imbalances during discharge and this BMS will have an impossible time re-balancing them during charge.
But, explain me, how I can still charge around 210A in these 2 110ah batteries, after around 50 cycles completed WITHOUT and NEVER balancing these 2 LiFePo4 ....
It's completely the opposite of what I've been reading here.
terry2 wrote:Burgerman wrote:Shirleys drunk again. But posted a blue spec sheet.
Again since you're too lazy to do your own home work.
https://overkillsolar.com/support-downloads/
That's their own settings files which you flash to the BMS.
Nothing like above pic.
Users browsing this forum: Kande_ian, LROBBINS, shirley_hkg, tettralytic and 917 guests
