Postby Burgerman » 07 Aug 2021, 20:59
Trick? No. Its all quite intuitive really. NON of the stock lead pesets are any good though.
So a question.
1. What are these AGMs?
2. Ah?
3. Are you charging on the bench in parallel or individually or in series?
4. Are you charging at restricted current with the XLR connector at 24V series?
5. Are you charging series/parallel via anderson(s)?
Then I will post a preset.
1. Connect to the PC.
2. UPDATE to newest firmware.
3. Install the preset in position 1 on your charger. Go to the top menu, choose OPEN FILE TO PRESET 1. And select the preset.
Postby LROBBINS » 07 Aug 2021, 21:19
You can read a preset file even if the PL8 is not connected, but to save that new preset to the PL8 it has to be powered up. Then just do what Burgerman said to replace an existing preset with the one he sends you.
Postby Burgerman » 07 Aug 2021, 22:08
DELETED
Postby Arima » 07 Aug 2021, 22:20
Burgerman wrote:Trick? No. Its all quite intuitive really. NON of the stock lead pesets are any good though.
So a question.
1. What are these AGMs? The brand is Mighty Max https://www.homedepot.com/p/MIGHTY-MAX- ... /308036968
2. Ah? 5
3. Are you charging on the bench in parallel or individually or in series? Hopefully both...with a different profile for 12 and 24. Not at the same time of course.
4. Are you charging at restricted current with the XLR connector at 24V series? No XLR, using 12g wire and bananas/alligators.
5. Are you charging series/parallel via anderson(s)? No
I look at what you posted. Need to get off my butt for a couple hours.
Thxs
Arima
Postby Burgerman » 07 Aug 2021, 22:44
Those are 14 times smaller than I was guessing at.
So I need to regroup!
Are you charging ONE or TWO at a time. In series or parallel?
Postby Burgerman » 07 Aug 2021, 22:58
These will do that.
Charge 2 dscharged series - Lead AGM 2x series 24V 5Ah batts.PS8
(3.19 KiB) Downloaded 104 times
Charge TWO Lead AGM 2x parallel 12V 5Ah bats.PS8
To charge a 5Ah 12V DISCHARGED single battery - AGM SINGLE 12V DISCHRGD 5Ah.PS8
(3.19 KiB) Downloaded 103 times
Postby Burgerman » 07 Aug 2021, 23:00
If you want to charge faster change the charge amps by double.
If they just need a small top up after a week doing nothing, otherwise full, then change the CV time to 4 hours.
Postby Arima » 08 Aug 2021, 03:01
Burgerman wrote:Are you charging ONE or TWO at a time. In series or parallel?
Only 1 at the moment. Your preset is working. Should have read the manual for the procedure. Went ahead and deleted all the old user presets. Still not sure what the difference is between User presets and Library presets. Finally have a charging station setup. Will try your other presets soon.
Thxs
Arima
Postby Burgerman » 08 Aug 2021, 11:06
All except mine are limited in low and high voltages, cell counts errors, and 101 other traps that bring up pointless error messages we dont need. And theres many hidden variables that I have changed so that they dont error and so they charge properly for both lead and LiFePO4.
So you can modify my presets to suit any batts you want to charge. Dont try it with any of the junk safety nazi ones with bad charge profiles that it ships with. All of those are full of problems for us. We are not charging tiny hobby batteries.
So want a lithium io phosphate one? STart with one of mine and modify to suit. Same with lead.
Postby Arima » 08 Aug 2021, 19:31
Yes this seems to be doing the job. Am sure I'll have more questions. Mucha Gracias
Thxs
Arima
Postby Arima » 09 Oct 2021, 02:24
So I've run into the proprietary pl8 balance plug issue. Did get one 36in balance cable. Has anyone found a matching connector? Otherwise my only choice is to cut the FMA balance harness and use a standard balance connector?
Thxs
Arima
Postby Burgerman » 09 Oct 2021, 11:10
I bought a dozen. So far used all of them on different packs. But the same connectors are available on chinese auction sites for self assembly. So dont panic. Its not an FMA or any kind of bespoke connector. Its a standard one.
Postby shirley_hkg » 09 Oct 2021, 13:17
$1
Postby LROBBINS » 09 Oct 2021, 15:24
Shirley, do you have a link (in English or Italian) for those cables? I wouldn't at all mind having some spares.
Postby shirley_hkg » 09 Oct 2021, 16:17
I buy from Chinese Taobao.
May be I can help.
Postage of a 500g envelop to Italy is £4, for lots of pigtails.
Postby Arima » 09 Oct 2021, 18:31
Well I haven't panicked yet. Think I might be getting numb to any electrical project issues. Everything seems to have hidden obstacles that usually require 3 tries before I can overcome them. This is just par for the course lol. But thanks for the calming influence! Now if I had a link that might get me the correct connectors on the first try that would be golden. It is a JST-pa 9 pin connector??
Found this one without wires lol...https://www.alibaba.com/product-detail/ ... 7004KRl4K6
Does that look correct?
Thxs
Arima
Postby LROBBINS » 09 Oct 2021, 18:44
Shirley, tell me how to send you the money and go ahead and order some of these for me - the single connector pigtail is what would be useful for me.
Arima, that is the correct connector, but Alibaba has a 1000 piece minimum order and you'd still have to connect wires.
Postby Arima » 09 Oct 2021, 18:52
Yes I saw that min order quantity. Hey whats a 20 mile detour for a 3 block trip to the store.
Thxs
Arima
Postby expresso » 09 Oct 2021, 19:56
https://media.digikey.com/pdf/Data%20Sh ... Series.pdf
you can check here - if it works let me know also :thumbup:
Postby Arima » 09 Oct 2021, 22:34
You know I just want to charge one cell with the pl8. DigiKeys has a 34 week wait time on these...https://www.digikey.com/en/products/det ... AGowAyvQZA
I guess it is a PAP-09V-S part #. Not seeing any on ebay at the moment.
If you have the address from wherever you got the pdf that might help Expresso. Or maybe Shirley will send a single bulk order say to myself (I'll pay you double your price) I could distribute them to other US members that want some?
With a little trimming I got this red jst connector to fit. But 9 pins is not possible this way. Maybe I will get some charging done later. I found a preset from 2019 on page 9 of this thread. Hope that is okay?
Thxs
Arima
Postby expresso » 09 Oct 2021, 22:50
dont have address sorry
maybe its worth just ordering some anyway and when they arrive - you have them - could be shorter than what they say 34 weeks - or longer - never know -
add your email to be notified
Postby Burgerman » 09 Oct 2021, 22:58
You dont need ANY balance connector to charge ONE cell.
You just need the correct preset...
Postby expresso » 09 Oct 2021, 23:01
https://www.verical.com/pd/jst-discrete ... nv_listing
your in luck maybe - try this one -
while your at it - get some that plug into this one also - both ends - you may need them down the line
well maybe not - min order is 448 - about 85 dollars - if others need some - i guess can resell
or call to ask for price on 20 of them - cant hurt to ask -
Postby shirley_hkg » 10 Oct 2021, 04:45
Burgerman wrote:You dont need ANY balance connector to charge ONE cell.
Really ?
It seems that's more accurate with balance port being fed .
Postby shirley_hkg » 10 Oct 2021, 04:50
LROBBINS wrote:Shirley, tell me how to send you the money and go ahead and order some of these for me - the single connector pigtail is what would be useful for me.
Will do, if you tell me how many you need . :dance
Postby Burgerman » 10 Oct 2021, 04:51
It probably is. Slightly. A few mV, but if charging until current is low, to top off anything above 3.500v ends up 100% full regardless. So how innacurate must it be to maKe any difference?
Postby Burgerman » 10 Oct 2021, 04:53
I could do with single pigtails too, 10 please. Tell me how much to paypal you! cheers
Postby shirley_hkg » 10 Oct 2021, 04:56
Don't think it's easy to diy a JST connector . It's way harder than you thought . .
Postby shirley_hkg » 10 Oct 2021, 08:27
Burgerman wrote:I could do with single pigtails too, 10 please. Tell me how much to paypal you! cheers
£14 including shipping.
Postby LROBBINS » 10 Oct 2021, 09:15
I'll also take 10 of the pigtails. Thanks.
Users browsing this forum: Andrey, Bing [Bot], LROBBINS, saker98 and 552 guests
