I am thinking of using the dual 24/12 volt Image B set up (see image below) for my upcoming LiFePo build per this thread.
I'll use 72 12Ah Headways in a 8 series, 9 parallel configuration for a total of 108 Ah. It would be set up as two 12 Volt batteries connected in series.
My hands not being very functional, I'd probably just leave the Image B loom set up in place rather than disconnect and reconnect as shown in Image C. My thought had been to have a compartment where that SB 50 could be tucked away so it would not be flapping around. But I may not have the room to do so. We'll see.
BM, you appear to use 10 sq. mm marine grade, hard insulation, tinned cable for your battery connections. I assume that ex-Goose uses the same in 6ga. Either way, that cable is not very flexible.
Using the dual 12V/24V charging set up shown in images A,B & C above, how the heck do you cram all that wiring into your battery compartment? Can the wiring loom be up so you can easily pull out the batteries without having to do a lot of disconnect work? My TDX -SP battery compartment would be very tight when it comes to installing the LiFePo battery shown above. I wonder about the practicality of routing all that wiring.
Now, I haven't had the opportunity to actually pull out the battery tray on my TDX-SP, but my building's multi-talented handyman did. Taking a look at the loom connector on top of my two MK gel batteries I see that the factory installed loom has an Anderson SB50 that 'blind mates' into a receiving SB50 at the front of the chair.
I think these are just standard SB50s and there is no purpose made 'blind connector'. (For example:
https://tinyurl.com/zkjhq34http://www.andersonpower.com/us/en/prod ... dmate.aspxSetting up a battery loom in the Image B mode above, I suppose that you could still have a blind mate connector to connect the batteries to the controller lead, but it seems that all the other cables required in the Image B set up would be problematic and you might have to do some manual disconnections for getting the battery out. I would like to make my LiFePo battery as idiot proof as possible. A LiFePo battery set up with all 'blind connects' would be ideal since it would allow the battery tray to simply be pulled out without any need for manual disconnections. Have you guys managed to set up your batteries & looms for easy removal?
