Burgerman wrote:Go to the top of device manager.
In the drop down boxes you will see SHOW HIDDEN DEVICES.
Now go down the tree and expand every item.
DELETE every single item that is greyed out... Will take a while
Now plug in the USB dongle FUIM3 and see what port it is using.
Now set the PL8s CCS to THAT port.
Now RESTART the PL8 and the COMPUTER. And finally open the CCS.
If you chose the correct port now load all the presets and say ready to start!
If not, throw away the USB cable and test again.
If still no connection turn the FUIM3 connecter 180 degrees and replug into the PL8 and reopen the PL8 CCS software...
Hi BM back from Lidl!!!
On the upside I'm buying 10 swg aluminium to make a Mark II version of the lightweight custom seat I made for the salsa, which has amazingly held up excellently and not collapsed on me while on the way to Lidl.
I going make it out of heavier gauge alu, 10swg/3.3mm.
I'd like to fine a 6 mph r-net rolling Salsa chassis to put the new seat on so I'd have a spare power chair. But not likely to find a rolling chassis so keeping me eye out for a bargain on eBay which will probably have lift/tilt which I might be able to flog.
Re bloody PL8. I went in device manager and deleted all the com ports then re-connected duff PL8. For duff PL8 CCS shows auto or COM 3 which is correct, but I still get that can't load the presets CRC message.
When I connect the good PL8, CCS gives the option of Auto of COM4. It connects to COM 4 fine and presets load.
Both the FU13 are fine, and checked them both by swapping them round.
All I can think is something has gone wrong in PL8 software?
Maybe I did wrong in connecting laptop to PL8 towards the end of the charge window. I used to do it like that as I didn't like the leaving the laptop outside on the scooter seat in case some thieving b**ard ran off with it
