Postby steves1977uk » 15 May 2022, 18:44
Fair enough. :thumbup: You can also use this... https://github.com/lostindark/DriverStoreExplorer
Postby Burgerman » 15 May 2022, 20:22
Steve. No email. What does it do thats different to this?
FILE REMOVED
Postby Burgerman » 15 May 2022, 20:32
Got it now, it puts it in the software folder. I see. I do that manually! And make a shortcut.
Steves one is here!
FILE REMOVED
Postby Burgerman » 15 May 2022, 20:34
Heres the FUIM3 driver, you could bundle this. But I never needed it on any PC.
FILE REMOVED
Postby LROBBINS » 15 May 2022, 21:06
Perhaps I should explain why our PCs are set to only update on command. If an update happens and notifications are off, should it cause a problem I will have trouble tracking it down. If notifications are on, and an update comes in when Rachi's speech output program is running, the notification steals focus and cuts off her access. So, Windows update is completely blocked, and I import a different OOSU10 settings file when I want to do an update (after I've made sure to have an up-to-date image stored in case the update causes problems), and then I import the "block all updates" OOSU10 file again.
Postby steves1977uk » 15 May 2022, 21:42
Done! Check your e-mail for version 2 BM! :thumbup:
Postby LROBBINS » 16 May 2022, 08:09
I've also downloaded it. Thanks.
Postby steves1977uk » 16 May 2022, 10:29
It will be easier for people to install CCS and FUIM3 drivers if needed. Why couldn't Revolectrix do this to start with? :problem:
Postby Burgerman » 16 May 2022, 11:33
Because they wanted to use that browser based thing...
Also 99% of people dont need a drver.
I think it would be better if the setup program had the option to install the driver. And not include that test software since we cant use it without test bench setup and knowledge we dont have. It just confuses people.
Postby steves1977uk » 16 May 2022, 13:14
The "dev" options are not included, and the driver is a manual install as the NSIS installer won't do this automatically unless I can't find that option. :?
Postby Burgerman » 16 May 2022, 14:33
Fair enough.
Postby steves1977uk » 16 May 2022, 20:47
I've made a version 3 of my CCS installer that allows you to optionally install the FUIM3 driver when you click Finish. I have removed the shortcut link for installing the driver in the start menu as this would confuse people.
Postby Burgerman » 17 May 2022, 00:03
Thats better.
Will post here in a few mins...
Finished version!
PL8 CCS Install.exe
(9.31 MiB) Downloaded 84 times
Postby steves1977uk » 17 May 2022, 00:24
Thanks BM! cheers Hopefully this helps people when they have to do an OS re-install or when they buy a new PC/Laptop. :thumbup:
Postby Burgerman » 17 May 2022, 01:33
You can do a new build soon.
With a bunch of modded presets, and all those uneeded files removed from the folder root.
Give me a day or two.
Postby steves1977uk » 17 May 2022, 11:13
Will do Boss! :mrgreen: I had thought about doing a version with your customised presets, but wanted the first one to contain the original files. :)
Postby Scooterman » 29 May 2022, 14:52
Do you find the banana plugs get quite hot when charging at higher ampage?
Postby steves1977uk » 29 May 2022, 17:13
There will be some warmth/heat due to the high currents, but shouldn't be unbearably hot to touch. Unless yours are loose/arcing for some reason SM? :? You could try cleaning them with some deoxit if they look a dull colour.
Postby Burgerman » 29 May 2022, 18:34
If charging with a PL8 for e.g the ONLY connectors that dont get super hot and melt are the ones they supply. And are also on Ebay and I buy them in 20 sets at a time...
Postby Scooterman » 29 May 2022, 18:47
steves1977uk wrote:There will be some warmth/heat due to the high currents, but shouldn't be unbearably hot to touch. Unless yours are loose/arcing for some reason SM? :? You could try cleaning them with some deoxit if they look a dull colour.
I did wonder if it's my soldering but I really don't think so. I wonder if they're cheap Chinese crap with low copper content?
Burgerman wrote:If charging with a PL8 for e.g the ONLY connectors that dont get super hot and melt are the ones they supply. And are also on Ebay and I buy them in 20 sets at a time...
Would you have a link to some you recommend BM. I find I have to reduce the charge amps to prevent mine getting too hot. I was concerned that very hot banana plugs would conduct their heat into PL8 and possibly cause it to fail hanged
Postby Burgerman » 29 May 2022, 19:35
Postby Burgerman » 18 Jun 2022, 10:46
I am baffled. Why not just update all to the latest 3.36?
Its a 10 second job, just 2 clicks to update in the CCS software and then all will work better for our purposes.
Postby shirley_hkg » 18 Jun 2022, 11:19
Here is another nice set of firmware version of 3.33 , completed with FUIM3 link.
Thoroughly checked to ensure all 8 balance pipelines are flawless, which is the most important thing to know.
Postby Burgerman » 18 Jun 2022, 11:42
How much? Delivered? Thats the important bit!
Postby steves1977uk » 18 Jun 2022, 11:48
As BM said above, why not update the units to the latest firmware Shirley? It makes sense since you're testing them... :thumbup:
Postby steves1977uk » 18 Jun 2022, 11:53
I got two for about £190 including shipping. They were the ones with 3.31 firmware which I'll be updating to 3.36 anyway.
Postby Burgerman » 18 Jun 2022, 12:00
Tempted to get another just in case!
Postby shirley_hkg » 18 Jun 2022, 13:38
steves1977uk wrote:As BM said above, why not update the units to the latest firmware Shirley? It makes sense since you're testing them... :thumbup:
I lost a precious one doing firmware update.
I prefer to leave it to its owner to decide.
Postby steves1977uk » 18 Jun 2022, 13:46
That's fair enough Shirley. :thumbup: Does your failed one have black squares on its LCD display?
Postby shirley_hkg » 18 Jun 2022, 15:54
Yes, but I think the 10 foot USB extension cable is to be blamed .
Users browsing this forum: Burgerman, emilevirus, wchl25 and 687 guests
