terry2 wrote:Burgerman wrote:You need to balance the pack every charge. Unless you KNOW it was in good balance already and DO NOT fully charge it. And only do that a few times max.Terry, what's the balancing current on the OverkillSolar BMS?
Only a tiny 80mA according to shirley, and only then if its a long way above the correct voltage. So its useless on a big pack. Esp if less than perfect/new. And already balanced by something else first. Hence he big list of warnings. But its got BT and nice graphics!
One more time for you.
It's programed by Overkill USA and you upload the latest settings from overkill site.
https://github.com/FurTrader/OverkillSolarBMS
But again. I am not saying dont use a BMS just that you should be aware of the issues instead of being in denial and thinking its some ind of fight.
The battery :
It's a 70Ah pouch cells , with loose, messy connections.
It's pre-balanced by PL8 , and is removed 60Ah out if it , and it is also deliberately unbalanced by taken 3 to 5 Ah amongst cells 3 to 8 as well.
It is an every way out of balance pack now .
Burgerman wrote:No its not.You can 99.9% charge a lifepo4 Cell (or a bunch of them with inadeqyuate balance capability. For a lot of the time.
But as soon as a cell reaches 99.9 full that cell then shoots up from 3.4V to a really high point. In seconds, after charging for many hours at 3.xx volts. That massive sudden rise at the last 0.01% is the problem. You obviously still put back most of the charge. But you damage a cell or two every time you do it. OR worse you never get it fully balanced. This gets worse every charge. And then one day you suddennly stop as a low cell that you didnt know you had (caused by a high one preventing a full charge on the others) makes your chair stop unexpectedly.
Theres 3 things lithium ion cells hate. Which severely shortens lifespan. Being full. Or above around 3.5V. ESPECIALLY if overvoltage and for long periods.
Being empty or below around 3V which happens to some cells if they are not correctly balanced.
BEing discharged at a high rate. Which means a pack that is double the size is twice as good. As you are only pulling half the amps per Ah. It also lessens aveage depth of discharge so no cell gets low which they do not like.
But I am wasting my breath. You will get nowhere near the 2000 cyvles you expect. And maybe you will get a breakdown or failure due to damaged cell long before you expect. And maybe it will just stop in the middle of one of your hykes far sooner than you expect.
I set charge volt @3.48V and balance starts @3.39V deliberately, to see how it performs at low charge volt.
Took 4 hours to rebalance the pack again .
No cell experiences higher than 3.48V throughout the charge.
Cell volts are solidly packed together , and have to wait 60 mins to drop to 3.43V for BMS to remove over-volt cutoff and continue.
See the log by PL8.
Yes. There are BMS
that could still do the job , though may not be as good as a PL8.shirley_hkg wrote:
The battery :
See the log by PL8.
Provide you don't apply a BMS blindly , and make adjustments to get around its weakness.
Many just want to charge their batteries, I suspect some like me don't really give a monkey's about all the fine details.
Find something that is at your level. Feel free to remain in the ranks of the masses that are clueless. And in the hands of the "experts". Suffer all the endless problems that all those around you do.
Knowledge is power. You dont want any thats your choice.
Burgerman wrote:Many just want to charge their batteries, I suspect some like me don't really give a monkey's about all the fine details.
And whats stopping you do that?
You dont give a monkeys if it damages them or is dangerous right? So carry on!
Dont need to read anything here.
This is a technical forum, so I'm not complaining.So what do I do?
Answer everything in a dumbed down way, knowing that its missing a lot ...
sacharlie wrote:Burgerman wrote:Many just want to charge their batteries, I suspect some like me don't really give a monkey's about all the fine details.
That is very irritating! Why do you insist on always doing that?
Activ Balancer module high frequency equalizer
-To actively balance the cells.
-Can also be operated without a BMS.
-Always keeps the cells at the same level and is recommended, as there can be problems with passive BMS.
-Modules are expandable and can be connected to each other, e.g. to balance 8 cells.
Data:
Manufacturer QNBBM
Consumption <50mW
Equalizing current balancing 300mV with 1A / 1V with 3A
Connection type terminals
Temperature range -40 degrees to +80 degrees
Users browsing this forum: rover220 and 134 guests
