Burgerman wrote:Lets try again.
I already asked you to TEST this. You ignored me again.
1. SET turn speed, and minimum turn speed to 7.
2. SET the YELLOW fields, AS BELOW:
Do the ADVANCED ELECTRONIC STABILITY first on its own. And do not set is above 55. And TEST. It should help you.
3. AFTER you test the ABOVE (2) then test the FRONT WHEEL DRIVE TYPE as shown, seperately. So you know how that feels. It MAY help you or may make it worse. TRY these SEPERATELY.
Then TEST With video so I can see.
TurnAtFullSpeed = 60; // range = 20 - 100. 100=no reduction of turn rate with speed, 20=turn rate
// is 20% of normal at full speed.
// particularly useful for front wheel drive chairs
CompTurnBoost = 65; // milliohms, range = 0 - 767
/* Because heavy loading of casters on some chairs can make it difficult to
start a turn when not moving, CompTurnBoost provides extra compensation in
that situation. This extra boost disappears as soon as current drops when
the caster starts to swivel. The effect of this boost also decreases as
fore-aft power increases, and becomes zero at 5% fore-aft PWM which is enough
fore-aft movement to straighten even heavily-loaded, difficult to swivel casters.*/
I am not familiar with the RNet parameters, but there may be equivalents to some of those I have in my homemade CANbus system.
Even though this more than doubles the baseline compensation (50 mOhms on her old chair), because it acts only in this special circumstance it won't lead to runaway. Even the basic compensation is somewhat protected from runaway if set too high because the motor current sensors go only to 100 Amps, so limits the added command.
Burgerman wrote:If you dont want the chair to do unexpected things they are both important.
You ignored everything I spent 30 mins typing in the last post again. This is becoming tiring because you do not respond, or appear to even read what I write.
greybeard wrote:Burgerman wrote:If you dont want the chair to do unexpected things they are both important.
Can't help feeling you are being played, BM.
daveonwheels wrote: no,q700m does not speak english
when I put the compensation at 30mmohm I was happy, because the wheelchair was very drivable and overcame obstacles and slopes without difficulty.very low speed 1 then 2...3....4....5 quickly with the right wheel that took a hole and the chair turned on itself.
Burgerman wrote:I give up.
I explained this in 20 different ways.Over and over. In dozens of posts that you wont read or dont understand. And STILL you keep asking the same thing.very low speed 1 then 2...3....4....5 quickly with the right wheel that took a hole and the chair turned on itself.
Thats EXACTLY what I would expect with low compensation and rediculously low turn acc and turn deceleration. (10th time of answerin this same thing)... And the last time.
You configured your chair to be uncontrollable and dangerous. Because it doesent "jerk"... And so it is dangerous... Which you also dont like.
But you will not configure it so that its safe and controllable because then you cant drive it. Because of lack of hand skills...
And you wont reply or comment on anything I suggest that may help. So I am out of here.
forgive me. last question
then I raise the acc and the turn decelerations to 100 and keep the compency low?
q700m wrote:can the flag switch only be used to change profiles?
Burgerman wrote:The profile I made already does that. ONE profile, and the right switch sets the SPEEDS in 5 steps. Those are the minimum forward speeds and the max forward speeds set inside programming. You dont need more than 1 profile to do that. It already does!
Anyway since you never replied to anything I say or suggest or ask, and keep on asking the exact same question for 6 pages I am out of here! No longer replying.
Users browsing this forum: Andrey, LROBBINS, shirley_hkg and 179 guests
