Burgerman wrote:HOW are you powering this Roboteq ON?
- as described in manual. using 24v setup
Do the graphs work, can you see input and output?
- graphs work, i see joystick input. motor outputs are low.
Did you copy all my MOTOR settings too?
- loaded both configuration and script. changed calibrations according to my joystick, speedpot and sensors-
Check battery upper/lower limits as I am using 45V...
- upper limit chaged to 35v, lower limit to 14v
I JUST LOOKED. SEt under voltage limit to 14V on yours. Its currently set to 30 volts. It thinks your battery is flat.
graph claims that battery voltage is dropping to 13v as i move the joystick forward, then it is gradually rising back to 27.6V. if i measure battery directly at the same time with manual meter it shows 27.6V all the time. i have just loaded battery full.
