ex-Gooserider wrote:I don't know about the new models, but my early ZXD with the original "fancy case" mod (installed by me) has three banana jacks, +, -, and ground. Per my meter with the supply off, + to ground is open loop, - to ground is about 5.8Mohm, and ground to case is 0, so it seems pretty well isolated...
Correct. ZXD must be grounded.
But, in many, many switching power supplies, the negative terminal has a direct connection to NEUTRAL.
Quite possible that the PL8 has floating outputs, but I was not asking about the PL8. I want to know about the ZXD.
c500user wrote: What I would like to have confirmed before ordering them is if the newest ZXD that shirley sells at the moment have floating outputs. Shirley, are you able to confirm?
Burgerman wrote:And the new ones, old ones, and everything in between use the exact same internals.
martin007 wrote:I have a problem with ZXD2400.
It makes a "click, click, click", but it doesn't start.
Any idea what the problem might be?
shirley_hkg wrote:martin007 wrote:I have a problem with ZXD2400.
Not the first time I recall.
Have to find a way to secure the AC plug.
woodygb wrote:
Like this?
Burgerman wrote:You took a thing of beauty or at least neatly stylishly engineered and made it "redneck" build.
Burgerman wrote:I am not wrong!
PL8 is the same negative on its input and output. Same actual black cable goes in one end and out of the other!
The ZXD power supplies outputs are floating. As in the AC IN has no bearing on the output at all. And you can (and I do) use them in series.
Think about it. If not and with a normal 2 pin USA style connection that is reversable, there is no "neutral" or live as it can be either way around! Then the POWER SUPPLY negative output would be at an unsafe 120V or 55V depending on how the house/transformer is wired. Or whichway you turned the AC connector in the wall... And that is not the case. And I would get smoke when charging a series 13S battery with 2 chargers and 2 supplies!
On my older ZXD, with three banana jacks, + and - are isolated, but the ground jack connects to the fancy case, and so does the earth ground from the AC outlet...
Users browsing this forum: No registered users and 360 guests
