It's about 5 to 8 amps on flat smooth surfaces and 120 amps on thick carpets/grass/mud etc...
its not being stressed too much - this is what i understand - is that correct ?
Burgerman wrote:You can if you make a short Y lead and plug both in.
This Headway 40152S 15Ah certified cell has a continuous discharge rate of 3C, and maximum pulse of up to 10C
expresso wrote:i guess its confusing since the specs on the EV site - says 150A
http://www.evassemble.com/index.php?mai ... cts_id=175
dosnt mention pulse etc, - says continuable
This guy is doing 10 at once... https://www.youtube.com/watch?v=WY194Md6KNg
shirley_hkg wrote: Rewiring of your big pack is unnecessary .
Each of your add-on pack should have two D-sub connectors , one female and one male .
Then you can do endless count parallel charging .
Burgerman wrote:Yes apart from the termination mA setting will need increasing a little. So save a new preset. Then you have one for 105Ah and another for whatever size both combined are.
the wiring i have on the cable SB50 from the chair to connect the ADD ON now is 10AWG -
Burgerman wrote:Try it.
Burgerman wrote:If it gets hot...
Users browsing this forum: No registered users and 359 guests
