PGDT SP1 vs pp1 programmer
Re: PGDT SP1 vs pp1 programmer
Postby Porkchops » 08 Dec 2016, 17:23
Hi I'm working on a Pride Go chair and have all the curtiss Wright leads but have been informed that pride use the pp1 or a simplified software for them only and will not sell me the software. is there software available to read the pride range of controllers and if so is there anyway of obtaining a copy?
Porkchops
Postby Burgerman » 08 Dec 2016, 17:24
see pm
Postby Porkchops » 08 Dec 2016, 17:59
Many Thanks for the quick reply but its still not reading the pride go chair or the new jazzy air and curtiss have said its a simplified software that you can only get from pride who are very unhelpful and only want to sell the hand held programmer. Is there any other types of software available for the power chairs?
Porkchops
Postby Burgerman » 08 Dec 2016, 18:01
I think you may be wrong but avoid anything pride for this exact kind of reason. What does the controller look like?
Postby woodygb » 08 Dec 2016, 19:04
The spec for the Go chair GC3 joystick say's non-programmable.
Postby Burgerman » 08 Dec 2016, 19:28
Well maybe non user adjustable. But someone originally programmed it! But its looking like a no go go... chair. :oops:
Postby Porkchops » 08 Dec 2016, 22:42
Oh well that's a bummer :| thanks anyway but Woody can i ask where you got that chart from?
Porkchops
Postby woodygb » 08 Dec 2016, 23:06
Postby Porkchops » 13 Dec 2016, 21:40
Thanks for that but i have just realized thats the new go chair. Mine has this controller below which i was able to read today with a PP1A and but was unable to reset the trips. Is there anyway to update my pp1 to an oem level or software to use with my lead?
Porkchops
Postby woodygb » 13 Dec 2016, 22:50
Reset trips? ... you can't "reset" trips with programming software or the handheld .... "trips" are a hardware fault .
The trip codes should however help you with identifying the problem.
How old is your chair ,what programming lead did you use and which PGDT version PC software did you try that didn't work?
Postby Porkchops » 13 Dec 2016, 23:29
Oh ok my chair is about 2 years old and and tried three different software versions i tried the latest dealer version from curtis wright and also a v8 and v14 of the manufacturing software. The cable was supplied from curtis wright about a month ago. Hope you can shed some light on this small but annoying problem
Porkchops
Postby Porkchops » 13 Dec 2016, 23:32
and also sorry i was supposed to say trip logs if that helps
Porkchops
Postby woodygb » 13 Dec 2016, 23:50
Strange why the PC Software doesn't work and the handheld does... perhaps your install of the PC software is at fault.
Any complaints from the PGDT Software on start up ... e.g. Unable to open COMMs port or something similar?
The Curtiss lead came with a USB - Serial adaptor? .... did the ( FTDI ? ) drivers install correctly?
FTDI recently ( Feb 2016 ) updated their drivers to deal with counterfeit chips ...it maybe worthwhile picking an earlier driver.
Postby Burgerman » 14 Dec 2016, 00:57
This almost always comes down to a comm port configuration error.
Postby Porkchops » 16 Dec 2016, 12:26
a quick update i've managed to read and clear the logs on the gochair with the pc software but have to program with the pp1 as the pc still will not read that.
Porkchops
Postby woodygb » 16 Dec 2016, 12:37
Weird!
Can you take a screenshot of the connected controller / PC software and post it.
Postby kungfuwitch » 22 Jul 2020, 20:27
I know this is an old thread but I wonder?
I purchasedWoodygb'programming cable, to hopefully 'take a look at' and maybe change some of the parameters on am S-Drive mobility scooter controller. (See pic) This was over a year ago now and I can't find any software to address this on a pc. Can anyone help out any? I'm being run around in circles @ Curtis Wright as it seems I would have to register and purchase some proprietory tools. To get further along with this. I am limited in how long I can spend down rabbit holes because of disability. So if anyone can provide an actual downloadable source for the pc software. I would be indepted.
P.S Woody's cable is on the left and I thought I also possibly needed the extra cable on the right. But I can't think why off hand. :oops:
Many thanks ahead!
kungfuwitch
Postby woodygb » 22 Jul 2020, 20:35
You have a P.M. ( private message ) ...and you do not NEED the extra cable on the right....but it maybe useful should you wish to extend the programmers plug in point so that it is outside of the scooter cover.
Postby JimBob1975 » 02 May 2024, 00:20
Hi,I am after a programming cable to connect to the s drive controller. Please can anyone help. Thank you so much peeps.
JimBob1975
Postby woodygb » 02 May 2024, 01:12
I can probably help.
Which S-Drive ( Amps ) ...I assume that you are in the U.S.?
Postby JimBob1975 » 02 May 2024, 16:17
Hi,just a general cable for all models I guess. I am in the UK.
JimBob1975
Postby woodygb » 02 May 2024, 16:28
£30 including postage.
Do you have the software?
Postby martin007 » 02 May 2024, 18:56
Would it be feasible if I wanted to manufacture a cable like that?
Postby woodygb » 02 May 2024, 19:03
Martin ...You will find plenty of diagrams on the forum...use the later versions.
Postby martin007 » 02 May 2024, 19:11
woodygb wrote:Martin ...You will find plenty of diagrams on the forum...use the later versions.
Do you buy the connectors on Ebay or Aliexpress?
Postby woodygb » 02 May 2024, 19:16
Postby martin007 » 02 May 2024, 19:22
When the summer heat comes I might try it.
If I have any doubts, I will ask you already.
If there were no import taxes maybe I would buy from you.
Postby Burgerman » 02 May 2024, 20:26
Import taxes?
Thats the EU "protection" racket. They are anti business and anti everything else. But pro green, pro open borders, pro socialist, globalist and pro anti democratic. Did you vote for any of the above or that horrid woman in charge? Nope. Nobody did...
Postby martin007 » 02 May 2024, 20:29
You can call it whatever you want, but it's a reality.
I'm not willing to be milked like a cow.
Postby woodygb » 02 May 2024, 22:16
Posting anything to the E.U. has become a customs nightmare for the recipient.
Users browsing this forum: shirley_hkg and 78 guests
