which chair is best or better.
Re: which chair is best or better.
Postby Burgerman » 22 Mar 2016, 18:31
Not if it has the standard LED controller, then OBP is a no go. Which joystick type does carls chair come with?
I presumed the colour screen fancy one since its only about £35 more from pgdt. Doesent seem like much saving with the basic one. Even if he pays the extra its still super cheap compared to buying a programmer used or otherwise.
Postby carlo67 » 22 Mar 2016, 23:33
steves1977uk wrote:Not if it has the standard LED controller, then OBP is a no go. Which joystick type does carls chair come with?
I am getting the Hybrid.with r-net omni http://www.silema.nl/images/com_hikasho ... 948405.jpg
I am getting my new chair today.
carlo67
Postby Burgerman » 22 Mar 2016, 23:42
https://www.google.co.uk/url?sa=t&rct=j ... hg&cad=rja
Yes this has OBP if it is enabled. Make sure you get it enabled!!! It may already be enabled but passworded.
7.1 On-Board Programming (OBP)
This is performed using the Omni’s own display and front panel buttons. For
details of these buttons, refer to section Controls and Connections. From the
Omni, all system OBP parameters can be adjusted: for example, Speeds and
Accelerations.
OBP can be entered in one of two ways, depending on the factory
programming of the control system.
7.1.1 To enter OBP using a keypad sequence:
• Hold down the Profile button and then hold down the On/Off button until
there is a short beep. Note, the normal power-up sound will occur prior to
this beep.
• Release the Profile button, but continue to hold down the On/Off Button
until there are two further short beeps.
• Release the On/Off button, there will be a longer beep and OBP Mode
will be entered.
After the sequence has been performed and while the system remains
switched on, the Mode button can be used to sequence through all system
Modes and to return to OBP Mode. If the system is powered-down or there is no
OBP activity for 5 minutes, then the keypad sequence will need to be
performed again.
The other way requires a dongle IF OBP is not already enabled. "Phil" is WRONG...
Postby carlo67 » 23 Mar 2016, 00:01
Burgerman wrote:https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjx0YGxrtXLAhUC1hQKHRJJDDkQFggkMAA&url=http%3A%2F%2Fsunrise.pgdrivestechnology.com%2Fmanuals%2Fpgdt_omni_manual_sk78813-03.pdf&usg=AFQjCNHiFf9mEbS6Es4WHKibOMXmitCOhg&cad=rja
Accelerations.
this beep.
will be entered.
performed again.
but he won't enabled it
think you for pdf
I think I need a dongle because it is much easier for me
I have a limited hand controls
carlo67
Postby carlo67 » 23 Mar 2016, 10:50
carlo67 wrote:I found this http://www.sunrisemedicalspareparts.co. ... programmer
is this it?
is this it?
carlo67
Postby Burgerman » 23 Mar 2016, 11:00
No...
It will say OEM and it will not be hand held. PC based only.
Postby steves1977uk » 23 Mar 2016, 17:07
is this it?
is this it?
That one would be dealer only, as wheelchair repair techs/servicers only sell dealer versions.
Postby Burgerman » 23 Mar 2016, 18:32
think you for pdf
Insist!!!
Postby carlo67 » 05 Apr 2016, 04:18
geez lol my new chair is slowly and not smooth as like my old chair
carlo67
Postby carlo67 » 16 Aug 2016, 07:30
my carers find the charger plug difficult to get to . I am wondering is there extra cable and plug so it make easier.
and
My new chair making some of popping sound when I turn around
I don't know where come from
carlo67
Postby carlo67 » 23 Aug 2016, 08:52
Thanks Carlo, but it’s not as simple as sending something up to you. We customise the remote sockets, so it will need to be fitted to the chair here I’m afraid.
As for the knocking noise, I have received the following from our engineering department:
The gearbox in our chair has helical gears, which mean that the shaft moves axially when the torque is reversed which causes a knocking sound. This is not a problem mechanically. There is nothing that can be done about this.
We can certainly check the chair over and see if there is anything wrong, but we can’t give unrealistic expectations. The reason helical gears are used is for strength, changing to spur gears to reduce/eliminate the knock would compromise the strength of the gearbox.
carlo67
Postby Burgerman » 23 Aug 2016, 09:24
The sound comes from the worm drive? Then they need to add shims or higher spec lower clearance bearings (C1 class) to stop it moving back and forwards. Thats just bad engineering or assembly standards. And as the bearings wear it will get worse.
As for charge connector there's no reason you cant add an extra one elsewhere, it is really simple.
What they really did was write a letter to stop you bothering them.
Postby Burgerman » 23 Aug 2016, 09:26
What is the chair again?
Postby hank » 23 Aug 2016, 09:51
John if its the groove gearboxes the small bearing on the worm drive gear
motor end. The bearings are cheap metal shield both end type.like a kids cheap scooter.
First to fail.Replaced with rubber sealed stainless ones and remove one seal
inside to get lubricated when running.
Postby Burgerman » 23 Aug 2016, 10:08
I lost track. I thought he had magic's V6...
Postby carlo67 » 23 Aug 2016, 10:08
Burgerman wrote:What is the chair again?
Frontier V6 – Hybrid
carlo67
Postby Burgerman » 23 Aug 2016, 10:14
It hasn't got a worm gear? :shock:
It uses inline motors.
Postby carlo67 » 23 Aug 2016, 10:30
Burgerman wrote:It hasn't got a worm gear? :shock:
I don't know
carlo67
Postby Burgerman » 23 Aug 2016, 10:32
I do. It has no worm. Unless it uses different motor/gearbox to the X5/V6 chair which I doubt.
Postby carlo67 » 23 Aug 2016, 11:39
where can I buy the remote sockets,?
carlo67
Postby Burgerman » 23 Aug 2016, 11:56
Postby carlo67 » 10 Sep 2016, 10:50
I found out of knock coming from https://youtu.be/x53V7kG-zJw
carlo67
Postby Burgerman » 10 Sep 2016, 12:23
Loose motor, loose wheel or loose hub, broken motor shaft, or something. Needs a man with a spanner to investigate and find out.
Postby carlo67 » 10 Sep 2016, 12:39
Burgerman wrote:Loose motor, loose wheel or loose hub, broken motor shaft, or something. Needs a man with a spanner to investigate and find out.
yep it is still under warranty
and I would like to know if I get bigger wheels. does it makes chair go faster ?
carlo67
Postby Burgerman » 10 Sep 2016, 15:18
Slightly bigger> Yes, a little.
Postby carlo67 » 10 Sep 2016, 23:35
,I would like to know if I can buy Grey or white wheels ? I don't want black
carlo67
Postby Burgerman » 11 Sep 2016, 00:00
Presumably you mean tyres? What size?
Postby carlo67 » 11 Sep 2016, 00:47
Burgerman wrote:Presumably you mean tyres? What size?
tyres for Frontier V6 – Hybrid https://www.youtube.com/watch?v=oMjMNCuqcd0
carlo67
Postby Burgerman » 11 Sep 2016, 01:05
Those use 2 sizes of wheel. A 6 INCH AND 8 INCH DIAmeter rim. Can you enlighten us? But in both cases there ill not be grey tyres that are bigger than stock on that chair.
Postby carlo67 » 11 Sep 2016, 01:24
Burgerman wrote:Those use 2 sizes of wheel. A 6 INCH AND 8 INCH DIAmeter rim. Can you enlighten us? But in both cases there ill not be grey tyres that are bigger than stock on that chair.
8 INCH can I buy grey tyres ?
carlo67
Users browsing this forum: Burgerman, emilevirus, JMGarage, snaker, Yennek, yeshelp and 138 guests
