signal i was seeking.differential H/L
Quite possibly they will not run from a USB port and need external power (higher current) to Arduino...
gcebiker wrote:I have not found anyone publishing their work using an MCP2551 to generate ASYNC serial.
And will test the Vin to make sure its getting power.
gcebiker wrote:Not yet been able to get it going (the mpc2551) , i can get a stream of '255' of it, not sure what i am doing wrong.
Ordered a MAX485 break out...a sabertooth is much cheaper than going this route but having gone this far...meh, may as well keep going.
as the needed 12-24v spike for 300ms would fry the digital out on my MAX485 and possibly the Arduino too.
/* written by Tony Matthews for the purpose of
Disabled assist sail winch control
in 303 and liberty Class Access dinghy's
One brushed bidirectional motor drives a main sheet winch,
One brushed bidirectional motor drives a jib sheet (liberty) or rudder (303's, 2.3's)
One brushed motor is a bilge pump, to empty any water that splashes in
Or operate signalling device, horn/light.
Code here in is written by Tony Matthews, whom has TBI.
TBI – Traumatic Brain Injury ...Use at your own risk.
For the benefit of Sailability Gold Coast, Queensland, Australia.
Serial.print is for testing.
tRexSerial.write is the software serial UART to communicate with the TReX.
Notes from Pololu's documentation.
--Motor Current codes --
Code needs one of each ie, current and current limit
0x13: motor 1 current limit (default: 0 – no motor 1 current limit)
0x14: motor 2 current limit (default: 0 – no motor 2 current limit)
0x15: motor 1 current limit proportionality constant P (default: 0x0A)
0x16: motor 2 current limit proportionality constant P (default: 0x0A)
--Acceleration Codes--
Acceleration used over 'set direction' as TReX has in built soft start/stop
Less wear on the winches to have soft starts.
Motor 1 - BiDirectional
0xC4 - Brake Low M1
0xC5 - Reverse M1
0xC6 - Forward M1
0xC7 - Brake low M1
Motor 2 - BiDirectional
0xCC - Brake Low M2
0xCD - Reverse M2
0xCE - Forward M2
0xCF - Brake Low M2
Motor 3 - Single direction only
0xF1 - Accelerate Motor M3
-- Motor speed settings --
May be represented as an integer as the Arduino converts it to HEX automatically (TReX reads HEX)
Must be positive number between 0-127
0 being stopped, 127 full speed
(Actual speed depends on acceleration logic and current draw V current limit)
eg M3 to full speed would be
tRexSerial.write(0xF1); //M3
tRexSerial.write(127); // full speed
All motor speed/direction/stopped need a speed value to go with them , eg stopped + 0 , forward + 127
//Software serial settings
#include <SoftwareSerial.h>
const int rx = 7; // rx pin of Arduino, SO(serial out)of TRex.
const int tx = 8; // tx pin of Arduino, SI(serial in)of TRex.
SoftwareSerial tRexSerial (rx, tx); // RX to SO of Trex, TX to SI of Trex
// Pot inputs
// Main sheet M1
int mainPin = A0; //input A0 for mainsheet
int mainVal = 511; // int to hold main Input value, start up in neutral 511
int mainValmapin;
int mainValmapout;
// Jib sheet M2
int jibPin = A1;
int jibVal = 511;
int jibValmapin;
int jibValmapout;
// dead band settings
int deadVal = 300; // will change to pot values , one for each axis
int midVal = 511;
int fwdVal = (midVal + deadVal);
int revVal = (midVal - deadVal);
int zero = 0; // integer for serial data '0' as 0 is ambiguous as used in a 'serial.write(0)'
// Power/speed variables
// Current limit (desired current limit in milliamp's / 150ma / 2 = ( )value)
// (rounded up) 2amps=7 , 10amps=33
int maxAmps = 2;//Current limit (desired current limit in milliamp's / 150ma / 2 = ( )value)
int overAmpbeh = 0; // over Amp limit behaviour 0=turn motor off
// data packet settings
unsigned char data[4];
unsigned long timer = 0;
void setup()
delay (1000);
tRexSerial.begin(19200);
delay (400) ; // wait for serial to start.
// Write TReX Motor Settings/Behaviour.
// build M1 data packet for current limit and proportionally constant
// build M1 current limit packet
data[0] = (0x80); // set parameter bit instruction
data[1] = (0x07); // TReX id number (if i had more than one, still necessary with only one)
data[2] = (0x13); // Parameter id, 0x13 for M1 Current Limit
data[3] = (maxAmps); // Current limit (desired current limit in milliamps / 150ma / 2 = ( )value)
// eg, desired current limit 2amps, ergo 2000/150/2=6.66, rounded up to 7
for (unsigned char i = 0; i < 4; i++)
tRexSerial.write(data[i]);
delay(10);
// build M1 Proportionally constant settings packet
data[2] = (0x15); // Parameter id, 0x15 for M1 Proportionally constant current Limit (pccl)
data[3] = (overAmpbeh); // Behaviour of PCCL current limit // Proportionally constant 0 (turn motors off if over current)
delay(10);
//Build M2 Parameter settings packets
//M2 data packet for current limit
data[2] = (0x14); // Parameter id, 0x14 for M2 Current Limit
delay(10);
// Build M2 Proportionally constant settings packet
data[2] = (0x16); // Parameter id, 0x15 for M1 Proportionally constant current Limit
data[3] = (overAmpbeh); // Behaviour of PCCL Proportionally constant 0 (turn motors off if over current)
delay (10); // give tRex time to apply settings.
void loop () {
// Main sheet control (M1)
mainVal = analogRead(mainPin);
delay(10);
if (mainVal > fwdVal) // Forward M1
mainValmapout = map(mainVal, fwdVal, 1023, 0 , 127); // map speed to return int 0-127
data [0] = (0xC6); // accelerate motor 1
data [1] = (mainValmapout); // Analog read val ,mapped.
for (unsigned char i = 0; i < 2; i++)
else if (mainVal < revVal ) // Reverse M1
mainValmapin = map(mainVal, 0, revVal, 127 , 0); // map reverse speed to return int 0-127
data [0] = (0xC5); //reverse accelerate motor 1
data [1] = (mainValmapin); // Analog read val ,mapped.
else // stop M1
tRexSerial.write(0xC7); // brake low
tRexSerial.write(zero); // zero integer value
//Jib sheet control (M2)
jibVal = analogRead(jibPin);
delay(10);
if (jibVal >= fwdVal) // Forward M2
jibValmapout = map(jibVal, fwdVal, 1023, 0, 127); // map speed to return positive int 0-127
data [0] = (0xCE); // accelerate motor 2 forward
data [1] = (jibValmapout); // Analog read val, mapped.
else if (jibVal <= revVal ) // Reverse M2
jibValmapin = map(jibVal, 0, revVal, 127 , 0); // map reverse speed to return positive int 0-127
data [0] = (0xCD); //reverse accelerate motor 2
data [1] = (jibValmapin); // Analog read val ,mapped.
else // brake M2
tRexSerial.write(0xCF); // brake low
gcebiker wrote:DG419 looks like it will be suitable, https://datasheets.maximintegrated.com/ ... -DG419.pdf
Users browsing this forum: Bing [Bot], Juggler258, tettralytic and 1037 guests
