snaker wrote:I write it in Xamarin. Basically, it can be built and deployed for all platforms Android/iOS/Windows. But for iOS I have to:
- Pay $100/year to deploy the app on App Store.
- Pay about $1.500 for a modest MAC laptop/PC to build the app.
- Pay about $500 for a modest iPhone to test the app.
It is an insane cost. Comparing to Google Play or Windows Store, a developer just has to pay $20, once for lifetime. Apple is really playing dirty, they are cheating both customers and developers. Personally, I do not find anything good in them.
snaker wrote:Yes, Xamarin had been extremely expensive ($2.000/1 developer/1 year?). It was acquired by MS some years ago. It is now a part of Visual Studio. Both Xamarin and Visual Studio are free for sole developers and small companies.
snaker wrote:What does "CCS" mean? My limited English
snaker wrote:I used ILSpy to decompile the PL8 software to source code. If you read its source code, you would have to laugh. It does not help much.
I mainly followed this doc
http://www.revolectrix.com/support_docs/item_1374.pdf
I also referred this library
https://github.com/coryrc/battery-cycler
Burgerman wrote:Did you disable (not delete) the unused com port that it creates?
Are you using a quality BT module on the laptop or PC? And have "allow the PC to use power saving" or whatever its called disabled in the properties tab in device damager?
Do you have the correct baud rate set?
I had a similar issue. Installed a low drop diode in plce of the simple silicone signal diode, added a couple of .1 caps, and a larger electrolytic to the module power input as its a noisy supply, as well as ferrite rings. And connected it via all 3 of the external pins on a servo lead. And left the BT module inside wrapped in heatshrink. Its been perfect ever since. Not sure which thing(S) fixed it...
stevelawiw wrote:still drops out on Snakers app
Because I had problems on both input devices I changed something at the PL8 end, I made it so that the UBEC is powering both the BT board and the 3 pin plug in the back of the PL8 whereas before the UBEC was only powering the BT board.
Thats one of the things I did.
Never tried the phone thing, as 'aps' on phones anoy me! Well smart phones annoy me.
Users browsing this forum: Andrey and 72 guests
