It begins to act more, the further you push the stick forwards. Its not about speed, but the position of the stick. It acts like a restrictor plate, without actually having one. Its the electronic equivelent. Full forward stick = much less turning electronically.
The problem with that is that if you use this, combined with your already crazy low turn speed settings, it results in almost zero capability of steering when you are cruising along. So when you spot a big drain cover, a child runs out, or you need to correct the direction for another reason, say to go through a narrow gap. You cant!
So while it makes it possible for YOU to be able to go in a straight line (while having no fine control capability with your hand), it also prevents proper control in the event you need to correct your course. If I were a driving instructor I would say that you were not in full control of the vehicle. Especially at 8mph.
