Burgerman wrote:Because the BMS has a very weak balance circuit and the cells may not be all balanced initially, I think Shirley included a 3.6v 1A power supply to drag each cell up to full to give the BMS a chance to start with.
Otherwise if just 1 cell was say just 3Ah different to the rest, and the bms has a 100mA balance circuit, then the thing would need to be on charge for 3Ah div by 100mA = 30 HOURS to let the BMS balance it. That's 30 hours with the charger cutting in and out as the volts go over the limit again and again on the full cells. Or just turning off too soon with only some cells charged depending on what the charger and bms do between them.
I could be wrong. But he mentioned it in a previous post.
Dead simple these BMS things! Its a bit more of that TLC he mentioned. But hopefully only initially.
i understand the very first charge will be a lone one - so i will end up leaving it on the charger how would i know when its done ?
and it seems thats just want i did to myself -
expresso wrote:I Recall Shirley - Saying for the very first time charging it - to use the slow charger XLR port - i can use either a 8 amp charger or a 5 amp charger for that process which is better suited for Gel batteries - or the 8 amp which is 28.8V charger
Shirley would have to explain how to do it when i am at that point -
Scollard - i can get the orange blocks ready the way you sent me the pictures - to use the 4 hole buss bars - will have them tomorrow - the buss bars on Wed. and my friend helper can help me on Friday for sure -
So if you can - you can explain or and show how do i postion the Cells now - i was following the other picture with the 2 hole buss bars - but with the 4 hole - its different
i need to know for sure how the Cells get arranged in the orange blocks - the first two would be Pos both of them - and at the other end both Neg - i think thats correct. - now the rest i leave it up to you
i understand the very first charge will be a lone one - so i will end up leaving it on the charger how would i know when its done ? i have to make a wire now SB50 from the pack to the chair - and find something to sit this pack in - before putting it in my back pack - have to get something to wrap it in also - can i use the clear plastic wrap that is used in the Kitchen for covering leftover food etc, - saran wrap ?
expresso wrote:Ok just to be sure - the orange blocks you want me to put them together the same way - the pictures you sent me - for using the 4 hole connectors ?
shirley_hkg wrote:In view of the small add on, 12 ah or 24ah at most, and all cells are 3.3V on arrival seems well balanced , I recommend to let the BMS --- TO DO THE INITIAL CHARGE . See what comes up and do individual balance at later stage.
Satisfactory outcome is expected and let's hope for the best.
You should assemble your cells to form a 24V pack NOW. Take pictures and we guild you hooking up the balance wires and the BMS. Start the first charge.
Lastly, put the cell monitor aside to avoid complexity at this stage. Good luck.
Scollard wrote:
Shirley, does the BMS have lights to show when cells are in balance?
expresso wrote:At Scollard - I will arrange the orange blocks later - and post picture back - in the event i wanted to add another Roll of 8 Cells later on after this is all done - would it be easy to do with the connections and how are arranging the orange blocks
being that we are using the 4 hole mostly - -
i got the Rest of the Cells today - all 16 Cells checked out at 3.3V - Wed. i would have the rest of the buss bars
expresso wrote:i will be careful once i get the buss bars and will take it step by step as Scollard will guide me along that way - first the orange blocks and the Cells in there place - then i will post the pic -
not connecting anything yet - till i get the rest and till i get instructions from Scollard to be sure and safe - - Very cold here - but my apt. is very warm - dont need more heat
Users browsing this forum: Bing [Bot], ebc, shirley_hkg and 126 guests
