Burgerman wrote:Or long charge cables... group 1 always reads differently on all my packs with long cables.
Burgerman wrote:The problem is that if one cell is bad connection or bad cell, that GROUP of 7 becomes empty first and you keep driving as you do not know. So all 7 cells end up bad because over discharge.
So best to find the problem, and fix or you will need 7 cells! As it is you likely need one, and you have one already spare.
When you measure you are looking for mAh out as it reaches 2.9v.. One cell will be bad, much less Ah than the others.
steves1977uk wrote:expresso, what's the Internal Resistance reading for cell group 1? If it has a higher value than the other 7 cell groups, that would also indicate a problematic connection or cell.
expresso wrote:steves1977uk wrote:expresso, what's the Internal Resistance reading for cell group 1? If it has a higher value than the other 7 cell groups, that would also indicate a problematic connection or cell.
Hi steve - i believe i clicked that tab on the PL 8 but didnt see any information on the IR of the groups -
Users browsing this forum: No registered users and 394 guests
