Postby shirley_hkg » 25 Apr 2017, 02:42
This is 18kg for 8 cells only @$HKD
Postby ex-Gooserider » 25 Apr 2017, 02:52
Worth noting that the biggest difference in price I found when shopping for batteries was in shipping cost - I specified delivery to my house in MA within 10 business days or less, and everyone's quote at least claimed that - but the shipping charges varied by over $500 for the same goods...
$700 is on the VERY high range of what I got for quotes, especially for 'slow-boat' post...
Postby Gnomatic » 25 Apr 2017, 03:18
ex-Gooserider wrote:$700 is on the VERY high range of what I got for quotes, especially for 'slow-boat' post...
Unless I'm mistaken, Shirley is quoting HKD, not USD. Unless I'm mistaken, the HKD/USD ratio right now is 7.78/1, so not so bad.
I'm still interested. :)
Postby shirley_hkg » 25 Apr 2017, 03:38
You are right ...
Postby Gnomatic » 25 Apr 2017, 03:52
You are right ...
Shirley, is this something you can facilitate? I'd like 18 of these cells, 16 minimum.
Let me know
Postby shirley_hkg » 25 Apr 2017, 04:12
Here comes the hardest part .
Post office won't take battery . Therefore , I can only send them out anonymously . This gonna be a hit-and-miss . :x
Postby Vitolds » 25 Apr 2017, 22:20
Vitolds
Postby expresso » 25 Apr 2017, 22:52
I am back in action - i reinstalled my pack last night - thanks to Quickie for doing the work :) along with my other girl to help her -
cant wait to test it outside - maybe thursday if not raining - i will also demo the Bounder Chair next Wed. with there lithium package
Postby Gnomatic » 25 Apr 2017, 23:52
Vitolds wrote:https://item.taobao.com/item.htm?id=539377155170&toSite=main
No way 16 of those fit in a Group 24 space.
Postby Gnomatic » 25 Apr 2017, 23:53
expresso wrote:I am back in action
Nice!
Postby Gnomatic » 26 Apr 2017, 02:49
shirley_hkg wrote: This gonna be a hit-and-miss . :x
So you drop ship them and I pray they don't get intercepted by customs or something?
Postby shirley_hkg » 26 Apr 2017, 04:15
Sadly that's the best I can do . :(
Seller asked for US$450.00 for shipping 16 cells to the USA .
Postby Gnomatic » 26 Apr 2017, 16:08
Yeah that's about the same shipping quote they gave me - so shipping would cost as much as the batteries.
Its still a decent deal *if* the batteries are as advertised. But not quite as appealing as before.
Postby Gnomatic » 27 Apr 2017, 00:36
I could fit a 160Ah worth of these cells in my chairs.
But at 220mm, probably a bit on the tall side to fit your new chair, BM.
Postby Burgerman » 27 Apr 2017, 01:04
Yep! 200mm inc wires..
Postby expresso » 28 Apr 2017, 16:16
Another user sent me this link - i know it uses a BMS - and it may be too large i think to fit - But if it can fit in someones chair - this would be a real plug and play - not sure how good it would work - cost is not bad for a large size also
you would need two of these and thats it - total cost looks like it can be under $1000 for everything - would need a faster charger than 3A thats for sure -
figure i post it here if anyone may be interested -
http://www.lifepo4.in/12v100ah-lithium.html
Postby Burgerman » 28 Apr 2017, 18:03
2 of those wont fit will they? Or if your battery area is just right for odyssey, you can get 4 in.So 200Ah. But the real problem is that more compact because its a lithium ion battery. 500 to 1000 cycles, and it burns really well!
Postby Gnomatic » 28 Apr 2017, 20:43
I could fit four of those. But those packs aren't LiFePO4
Postby Burgerman » 29 Apr 2017, 01:35
OK for those that can get off the chair fast and run away. But a fault or overcharge due to bms failure etc may burn your house down.
Postby expresso » 29 Apr 2017, 17:25
Ok i see - i didnt realize those are not the same Cells we use - i wouldnt play around with anything other than the safest cells which are what we are using -
Postby expresso » 29 Apr 2017, 18:29
http://www.lifepo4.in/lifepo4.html
but they say - show lifepo4 ? i though there was only one kind of LifePo4 ? that can be confusing then for others searching around - i though once i see LifePo4 - as the battery type - that was the safe one - and then of course all the other details need to be good enough - size - if it has a BMS which they all do - etc, etc,
Postby expresso » 29 Apr 2017, 19:09
http://www.lifepo4.in/app%20ebike%20bat ... ttery.html
isnt this LIfepo4 pack ? if so - for $500 delivered - you get it ready made 24V 40ah pack - plug and play - if thats correct - its an option - even if not the best option -
Postby Gnomatic » 29 Apr 2017, 20:56
This one is not LiFePO4. It's Lithium ion.
This one is LiFePO4. But only 40Ah. No better than lead. And two won't fit.
Postby expresso » 29 Apr 2017, 23:44
Ok - i figured the one that is Life and at 40ah - can be used as a ADD ON maybe for someone who isnt willing or wants a simple plug and play -
i am not interested in them really but like to see how things are getting closer to one day - its a doable thing - even if not perfect solution -
its easy enough to make a ADD ON - but still some may not be able or willing to do it - and rather just have a plug and play even if not perfect
Postby Burgerman » 30 Apr 2017, 03:44
It would work as an addon but its huge.
Postby shirley_hkg » 30 Apr 2017, 04:32
Manufactures are reluctant to use low cut-off BMS like the one I bought you .
Instead , they are MORE eager to pump up the capacity , by using BMS with high cut-off , 3.75 /3,85 V . Cells will get swelling , in a year or two .
Postby Andrey » 30 Apr 2017, 15:40
Battery monitoring after natural ~30Ah discharge (of 84Ah total) in still and with movement loading, also charge graph later.
Seems that difference -0.007V for cell8 are all time the same.
p.s. remove ".zip"
BM2-L-monitor-28 04 2017.CP8.zip
(13.43 KiB) Downloaded 232 times
BM2-L-charge-28 04 2017.CP8.zip
(91.26 KiB) Downloaded 241 times
Andrey
Postby expresso » 30 Apr 2017, 16:02
shirley_hkg wrote:Manufactures are reluctant to use low cut-off BMS like the one I bought you .
i see - if the BMS you got for me is used in these packs - then they could be a good option - if size fits in a backpack etc, - i am sure even the bounder Chair which had a lithium option - i believe they charge up to 29.2v - to get them all full and balanced - i think that comes out to 3.65V a Cell - thats still a safe level ? its the very top of the safe level -
Postby Burgerman » 01 May 2017, 01:26
0.007v isn't much. Most multimetres are not that accurate and couldn't measure it. But theres is a reason. It may even be a charger calibration fault. Or slightly bad cell, or bad connection/loose bolt. Its so small that I might ignore it for now. And keep an eye on it.
Postby Andrey » 01 May 2017, 15:54
Burgerman wrote:0.007v isn't much. Most multimetres are not that accurate and couldn't measure it. But theres is a reason. It may even be a charger calibration fault. Or slightly bad cell, or bad connection/loose bolt. Its so small that I might ignore it for now. And keep an eye on it.
Thanks! I will :)
Andrey
Users browsing this forum: acid_coke, emilevirus, jehan and 598 guests
