). And it worked perfectly! The only thing I'm still unsure about is how to wire the circuit breaker in the permobil, positive cell 8 and 24v positive or something else?Superchunk wrote:So, update on my side, I tested it out in my invacare tdx sp2 chair (it takes 22NF batteries so had to take the battery tray out). And it worked perfectly! The only thing I'm still unsure about is how to wire the circuit breaker in the permobil, positive cell 8 and 24v positive or something else?
jefferso wrote:I wonder if 8 of these 100 Ah could fit in a Group 24 space on their sides:
https://www.docanpower.com/index.php?ro ... arch=100ah
100 Ah
(Width):160
(Height):118.5
(Thickness):50
4 x 50mm thickness = 200mm height, + 5 x 1mm insulation, 205mm (MK Gel = 209mm high)
118.5 mm x 2 = 237mm (MK Gel = 259mm length) would leave 22mm, 11mm for each set of terminals and connectors. Seems like not enough space.
160mm height, on its side, becomes width (MK Gel = 173mm width)
Burgerman wrote:You can increase termination current a little. By around 25%. So if its set to say 200mA for e.g set to 250. Keep doing that until it ends after around 15 to 20 mins after it is at CV balanced. Its pretty good already. Manual fine tune! Its not critical. But why not.
Users browsing this forum: Burgerman, Juggler258, LROBBINS, Potty, shirley_hkg and 130 guests
