Postby Mechanic Bob » 07 Apr 2020, 22:44
I found the software thank you.
Mechanic Bob
Postby sabain » 12 Jun 2020, 19:17
Reaching out here for help.
Same as others before im looking for oem copy of the software to program my
PG Drives Technology S drive controllers
Cheers,
sabain
sabain
Postby Joachim1 » 13 Jun 2020, 19:28
Hello people,
my name is Joachim and I come from Germany. I have a luxury problem. I'm currently building an older meyra allraund 900c with a pg pilot + control system into a chain-driven lawn mower. Since the speed backwards and the steerincontrol is too slow / damped, I wanted to have this corrected by a wheelchair service near me. Unfortunately he does not have the equipment to do this. Therefore I try this way. The cable should not be a problem due to the information here in the forum, but I would still lack the corresponding pc software. Can someone help me with that?
Many Greetings
Joachim
Joachim1
Postby Burgerman » 14 Jun 2020, 10:21
See PM.
Sabain too...
Postby Joachim1 » 14 Jun 2020, 11:13
Thank you.
Regards
Joachim
Joachim1
Postby sabain » 14 Jun 2020, 21:52
Thanks.
Regards
Sabain
sabain
Postby patrick » 26 Aug 2020, 14:58
Hello,
same as sabain and Joachim1 - I'm looking for a oem copy of the software for programming a PG Drives Technology S drive controller.
Greetings
Patrick
patrick
Postby woodygb » 26 Aug 2020, 15:32
You have a P.M.
The link say's VR2 ...do not worry ... the software is fine for the S-drive
Postby patrick » 27 Aug 2020, 06:47
Thank you and greetings from Austria.
Patrick
patrick
Postby frankenfir » 31 Aug 2020, 08:22
Im looking for oem pgdt s drive pc software right now i have a delaer level 14.6.0. Appreciate if someone her could help. :worship
frankenfir
Postby woodygb » 31 Aug 2020, 09:14
Check your P.M.
Postby cheeseball » 09 Oct 2020, 16:22
Hi, hoping someone can point me in the direction of the oem s-drive software, thanks.
Cb
cheeseball
Postby cc17926 » 30 Oct 2020, 17:37
Good morning from the soggy east coast US..
I have replaced the S-Drive in my wife's scooter (the D51270 model) . Can I please have a copy of the OEM programming software used to update the settings on the replacement controller board?
Thank you!!
cc17926
Postby woodygb » 30 Oct 2020, 17:41
You have a P.M.
Postby jk-tech » 31 Oct 2020, 05:55
Hello,
i*m also looking for the software, can anybody help me?
Many thanks
br
Jens
jk-tech
Postby aroli12 » 06 Nov 2020, 00:37
Hi Everybody!
My name is Roland and I live in Hungary.
I have a mobility scooter with S-Drive controller and I going to replacing the motor with a larger one. I would like to change the S-Drive parameters, but I have only Dealer version. banghead
Could somebody give me a higher version of Mobility PC Programmer? :worship
Thank you for your help!
Roland
aroli12
Postby woodygb » 06 Nov 2020, 00:54
The only parameter that you might need to change is the motor compensation value.
Postby aroli12 » 06 Nov 2020, 11:04
Thank you very much. I will check this parameter. :thumbup:
aroli12
Postby leon112233 » 12 Nov 2020, 17:02
bushytails wrote:Thanks - worked perfectly first time!
When I first saw the version without a diode, it seemed a bit odd that you could tie two tx pins together (the one from the cable, and the combined one on the controller) - unless they're designed to be used this way (which the cable very likely isn't, since it has separate rx and tx lines), they tend to fight each other, and not work. Having a diode makes much more sense.
Some details, if it helps confirm what does/doesn't work:
Cable: http://www.ebay.com/itm/121153158397
Diode: 1N4148, just because I have a pile of them.
Plug: Random XLR from my parts stash
Driver: Latest from prolific's website for XP, 2.1.44.226
Controller: 50A VSI.
Software: http://filebin.ca/qeVD8PXcQ5p/oem_programmer.zip
Total assembly time around ten minutes, most of which was finding parts.
There's still some lag, but it's much, much better. I need to try playing with the compensation and some of the other settings. The biggest problem is it takes too much stick movement to make a slight steering correction start, and seems to decelerate both motors, not just the one it should be slowing down to effect the turn. Some logic to prevent you from getting sideways, I think.
Thanks again,
--Bushytails
I'm working on a bumper car with the drivetrain of a mobility scooter, however we would like to program some things, the mobility scooter uses a Penny and Giles controller.
Could someone provide me with an active download link regarding the software?
Thanks!
leon112233
Postby Santimismo » 18 Nov 2020, 08:07
Hi woody, i need to find the SW to get conected to a sunrise salsa M2. Could you help me¿?
The ECU is a VR2 Quickie.
BR
Santimismo
Postby Burgerman » 18 Nov 2020, 11:31
See PM
Postby taycong » 02 Feb 2021, 17:52
Hello everyone, im a young guy from China, im making a go kart for my little son, and its driven by a chinese version PG motor controller, it comes with a wig-wag type throttle, i wanna change it into a one ending type ,like a car peddle one, so i think i need the programming software, can anybody help me , thanks a lot.
taycong
Postby woodygb » 03 Feb 2021, 00:36
Check your messages
Postby taycong » 03 Feb 2021, 01:32
Thanks a lot ,sir, wish u have a good one :D
taycong
Postby cikig36186 » 03 Feb 2021, 17:21
Hi, i need a software to connect with VR2, can you provide it to me?
Thanks a lot!
cikig36186
Postby Avia Mobility » 27 Feb 2021, 23:17
1) I too am looking for the OEM software for PGDT. The links here are all dead with "bandwidth exceeded". Can anyone help me locate the OEM version - or anything above the dealer version?
2) I am trying to reprogram a bunch of Invacare "SHARK" controllers so they will accept the generic DK-REMD01 joysticks. Has anyone had experience with this?
Avia Mobility
Postby henkserious » 15 Mar 2021, 19:51
Can anybody help me with the oem version? Many thanks in advance.
Greetings,
Jan
henkserious
Postby woodygb » 15 Mar 2021, 20:42
Check your messages
Postby Zelkin » 17 Mar 2021, 20:05
Hi
I need help :)
We have a car with S-Drive converted as an electric car for my nephews.
Unfortunately, the car now drives in the wrong direction and the brake settings should also be changed.
Can someone send me the appropriate software and tell me what I need for the 4Pin Molex cable :)
I have built a FTDI TTL adapter and the cable with diode and 47kohm resistor.
Is that enough?
Thanks for the help
Greetings
Zelkin
Postby woodygb » 17 Mar 2021, 20:26
Swap over the motor connections and the car will go in the other direction.
The brake on the end of the motor is just a PARKING BRAKE.
Cable diagram.
viewtopic.php?f=2&t=5523&start=180#p169035
Check your messages .
Users browsing this forum: LROBBINS and 188 guests
