rustyjames wrote: I haven't weighed my pack build yet but it's got to weight around 20 lbs.
rustyjames wrote:Expresso, how does your 646 feel with the add on, does it feel like it's more tippy when you accelerate hard? I haven't weighed mine pack build yet but it's got to weight around 20 lbs. the reason I ask is because I removed the anti-tips from a chair that I'm building.
rustyjames wrote:
I also think it's a good start to breaking into the lithium world, and for powering other chairs.
expresso wrote:http://www.ebay.com/itm/22-18-AWG-10-STUD-3M-HEAT-SHRINK-RING-TERMINAL-ELECTRICAL-CONNECTOR-Qty-50-/391795032792?hash=item5b38cdc2d8:g:qS8AAOSw-3FZJw~x
what ever makes you feel comfortable - as long as you crimp; them well and use these 3M with glue when you headshrink it - it seals it - -
snaker wrote:Thanks expresso, I found them. You are a search guru
Burgerman wrote:All mine did! I cut it off.
The 36" extension cable plugs in between the Cellpro PowerLab 8 and Cellpro pack (or adapter) for added convenience. Great when you do not want to remove the pack from your model prior to charging. Also makes hookup easier and extends the life of the connectors in the PL8.
remember one end will be Cut anyway and ring ends added to connect to the battery - make sure to have the female end left - then you can use the 36 inch cable from the PL 8
Users browsing this forum: emilevirus and 297 guests
